Faouweb Posted June 6, 2014 Share Posted June 6, 2014 Hi, When I change the UCS and want to rotate or move an object the GIZMO does not follow the UCS that I use, as you can see in the image: Thank you. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 6, 2014 Share Posted June 6, 2014 Have you tried using DYNAMIC UCS? Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 6, 2014 Author Share Posted June 6, 2014 Have you tried using DYNAMIC UCS? I use DYNAMIC UCS to draw on faces, but I don't know how to use it with 3d rotate Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 6, 2014 Share Posted June 6, 2014 (edited) I am too busy to try this right now, but you might try changing your system variable UCSFOLLOW value from 0 to 1. If that doesn't help, then you can reset it to 0 again. Edited June 6, 2014 by Dadgad Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 6, 2014 Author Share Posted June 6, 2014 OK thank you I'll try Quote Link to comment Share on other sites More sharing options...
zaphod Posted June 6, 2014 Share Posted June 6, 2014 I prefer 3D align over 3D rotate, and I never use dynamic UCS, I guess I'm old school and a control freak. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 11, 2014 Author Share Posted June 11, 2014 I prefer 3D align over 3D rotate, and I never use dynamic UCS, I guess I'm old school and a control freak. Hi, How do you if you have the situation as I have? I do not know how to do it using DYNAMIC UCS I have the same situation this morning and I can't continue. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 11, 2014 Share Posted June 11, 2014 What exactly are you trying to do? Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 11, 2014 Author Share Posted June 11, 2014 I want to rotate the Elbow 45 degrees, I have changed the UCS but the GIZMO does not follow the user UCS, here is an other image: I want to rotate on the Z axis. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 11, 2014 Share Posted June 11, 2014 I'm not a big fan of either Dynamic UCS or the GIZMO. I'd relocate the origin of my UCS to the center of the end of the elbow where it connects to the weldneck making sure it was oriented correctly (I believe your UCS is good in that regards) then use the normal Rotate command. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 11, 2014 Author Share Posted June 11, 2014 Thank you ReMark , RO worked perfect Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 11, 2014 Share Posted June 11, 2014 You're entirely welcomed. Glad to hear my "old school" suggestion worked for you. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 12, 2014 Share Posted June 12, 2014 (edited) Hi,When I change the UCS and want to rotate or move an object the GIZMO does not follow the UCS that I use, as you can see in the image: Right click on the Gizmo... Align Gizmo with > Current UCS Edited June 12, 2014 by nestly Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 12, 2014 Share Posted June 12, 2014 Welcome back nestly! Quote Link to comment Share on other sites More sharing options...
Faouweb Posted June 12, 2014 Author Share Posted June 12, 2014 Thank you very much nestly Quote Link to comment Share on other sites More sharing options...
