hosyn Posted June 6, 2014 Share Posted June 6, 2014 Indeed there are a lot of block in each drawing and i have to join them with ( pline or arc ) it's very easier than select them with drag mouse on them instead select one by one . are there any suggestion code??? i wanna with running command lisp we drug mouse on couple block and automatically joined together with pline or arc. Quote Link to comment Share on other sites More sharing options...
Organic Posted June 7, 2014 Share Posted June 7, 2014 i wanna with running command lisp we drug mouse on couple block and automatically joined together with pline or arc. Is it really that much harder to type pl (for polyline) and click between the blocks than it is to type X (for the lisp code) and select the blocks? If you want a an arc then how is a lisp code supposed to determine what size radius the arc has (chord length, some other measure?) and what direction the arc goes... Quote Link to comment Share on other sites More sharing options...
troggarf Posted June 7, 2014 Share Posted June 7, 2014 This one places individual polyline segments at the selected block's insert points: http://www.cadtutor.net/forum/showthread.php?79409-How-we-can-connect-selected-blocked-with-pline-by-lisp This one allows for continuous selection: http://www.cadtutor.net/forum/showthread.php?48265-Begin-line-at-block-insertion-point/page4 Quote Link to comment Share on other sites More sharing options...
