meaty_matt Posted June 8, 2014 Share Posted June 8, 2014 Civil 3d 2011 So I have drawn in my proposed contours along a road They have been assigned elevations to the polylines and I go to Prospector, Surfaces, Make new Surface "FG", definition, contours, add I click all my new contours and they show up as a new tin surface but segments have been added automatically and at one point (a low spot) autocad has automatically made the low spot a closed contour where in fact it does close but not at that point. How do I have autocad just convert my exact defined lines and stop adding things? Quote Link to comment Share on other sites More sharing options...
meaty_matt Posted June 10, 2014 Author Share Posted June 10, 2014 ????????????????????????????? Quote Link to comment Share on other sites More sharing options...
meaty_matt Posted June 10, 2014 Author Share Posted June 10, 2014 I drew some polylines and made a new surface, added the lines as "contours" they came out 90% what I wanted them too but in a low spot autocad connected two ends of one line and made a oval and on alot of the other contours autocad added segments to them. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 11, 2014 Share Posted June 11, 2014 Triangulation depends on lots of things number of points the spacing of the points and the pattern of the points (note pline=a number of points) you need to look at the mesh and see where its going wrong a single pt to 3-4 pts is not the same as 4 pts to 4pts ie more triangles. Just taking plines I would look at creating more vertices to see if improves. Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 11, 2014 Share Posted June 11, 2014 This is me thinking aloud but if you are adding lines as Contours, and the line is not a closed loop, Civil needs to do something where the line ends. And as we all know, when you let Civil think for itself, it ends badly.... If you don't want a Surface where the lines are not, then I would look at adding a Boundary as well. Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 12, 2014 Share Posted June 12, 2014 Civil wants to see contours as closed loops, it's sometimes hard to change that. Would it work better if you added the lines as Breaklines instead? Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 12, 2014 Share Posted June 12, 2014 I merged your threads so that you have all suggestions in one place. Quote Link to comment Share on other sites More sharing options...
meaty_matt Posted September 24, 2014 Author Share Posted September 24, 2014 Thanks for the replies but not working. I'm not an everyday drafter, maybe 15 plans a year. Man I wish I could just draw ploylines and use terrain convert polylines like in old versions. Hard getting used to tin surface. In some ways its great, like the autoscaling labels and such, but with I could just draw polylines and have just what I draw be converted to a surface. Quote Link to comment Share on other sites More sharing options...
