crisraj99 Posted June 12, 2014 Share Posted June 12, 2014 i have a drawing in that so many blocks are available, i need a lisp to get the block names with respective layers in a notepad or .csv/xls file thanks in advance...:) Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 12, 2014 Share Posted June 12, 2014 Please check the built-in DATAEXTRACTION command. Quote Link to comment Share on other sites More sharing options...
crisraj99 Posted June 12, 2014 Author Share Posted June 12, 2014 Can you please give some details about "DATAEXTRACTION". Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 12, 2014 Share Posted June 12, 2014 Please check .Some side comments: Don't get confused about the command used, EATTEXT is the older name. The example is on attributes extraction, but for layer is similar. By the way, the layer property is found in General category. Quote Link to comment Share on other sites More sharing options...
crisraj99 Posted June 12, 2014 Author Share Posted June 12, 2014 thank you very much Mircea Quote Link to comment Share on other sites More sharing options...
