Results 1 to 8 of 8
    Senior Member Siberian's Avatar
    Siberian's Computer Details
    Windows 10
    HVAC
    Siberian's Discipline Details
    Engineer, HVAC
    HVAC
    Revit 2018
    Jul 2005
    Norway
    455
    Default How to edit anonymous blocks?
    I'm trying to edit a view-block for a multi-view part. But when looking at the different views in the multi-view part style dialog the view-blocks are all named U345 or some other number. This name can't be found in the list of blocks in the drawing, and so I'm not able to edit it. I've googled that blocks with this sort of name are called "anonymous blocks", but I still have no idea what to do about it to enable me to edit them....any ideas?
    If at first you don't succeed - remove all evidence you ever tried.
    Super Member CADMASTER1128's Avatar
    CADMASTER1128's Computer Details
    Windows 10, 64 - BIT OS
    Lenovo Y50
    Intel Core™ i7-4710HQ @ 3.40 GHz
    8 GB DDR3L
    Intel HD Grapghics 4600 and NVIDIA GeForce GTX 860M + 3GB Video Memory
    1TB + 8GB SSD
    WD MyCloud External - 2TB
    15.6''
    Construction
    CADMASTER1128's Discipline Details
    Badger Construction
    Construction
    Shell Builds, Remodels, Custom Homes
    AutoCAD 2015
    Apr 2009
    Tampa, Florida
    717
    Are you not able to select the block, then right click > "Edit Block In-Place" ?
    Using: AutoCAD 2015 (Vanilla)
    Tampa Bay Tech High School - Academy Of Architecture
    www.BadgerConstruction.com
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Can you attach a copy of one of the blocks to your next post?
    *U### uniformly scaled blocks can be exploded with the EXPLODE command.
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    I don't think they can be edited.
  5. #5
    Senior Member hertz hound's Avatar
    hertz hound's Computer Details
    windows 7
    Dell precision T1600
    Construction
    hertz hound's Discipline Details
    Electrician
    Construction
    Auto Cad as-built and coordination drawings when needed, otherwise in the field with the tools.
    MEP 2015
    Jan 2012
    USA - New Jersey
    138
    I just tried What you are looking to do. I tried it with stock content and custom content. I was able to edit the view blocks that I tried, so I am not sure why it is not working for you?
    In the edit style dialog box, I looked for the different view blocks that were used by the part. They all started with the part name and ended with Uxxx view block name. I left that dialog box and typed BE to open the block editor. I chose the view block I wanted to edit from the list, and had no problem editing it.
    For the two MVparts I tried, I could not find the name of the top view block for plan view. I used the name of the view block for two line. I block edit that block by drawing an x across it, and saved it. It was not evident that I changed anything until I selected it and in the display tab of the properties pallet, changed it back and forth to "By object". It took to the update. it would not do that with a regen. Sometimes that happens with regular blocks where you have to switch it out with another block and back to notice a change. I have noticed that with Tags that use MVBlocks.
    I tried it with other top view blocks and the X only showed up when I did it to the two line block as above. The X also showed up without manipulation of the properties pallet when I changed the display rep to MEP two line.
    So the only thing I see as being weird is that the MVPart has no block listed as being the top view block for plan View in the edit style Dialog box, and I had to try several before it made a change.
  6. #6
    Windows 10
    HVAC
    Engineer, HVAC
    HVAC
    Revit 2018
    Jul 2005
    Norway
    455
    These are screens of two different parts where one is OK, and the other is as I described.
    I have no idea why one behaves differently from the other...
    You see the part name at the top - they are both out of the box parts.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Please see your private messages. Thank you.
  8. #8
    Forum Newbie
    AutoCAD 2007
    Oct 2016
    1
    Quote Originally Posted by Siberian View Post
    I have collect a lisp.
    HTML Code:
     ;    UnAnon.Lsp                                   Jul 05, 1998
    (princ "\nCopyright © 1998, Fabricated Designs, Inc.")
    (princ "\nLoading UnAnon v1.0 ")
    (setq uan_     nil
          lsp_file "UnAnon"
     ; ================== For Automated Calling From Another Program
    (defun uan_auto (ar1) (UnAnon ar1))
     ; ================== Macros
    (defun PDot () (princ "."))
    (PDot)
     ; ++++++++++++ Set Modes & Error
    (defun uan_smd ()
      (SetUndo)
      (setq	olderr	*error*
    	*error*	(lambda	(e)
    		  (and (/= e "quit / exit abort")
    		       (princ (strcat "\nError: *** " e " *** "))
    		  (command "_.UNDO" "_END" "_.U")
    		  (uan_rmd)
    	uan_var	'(
    		  ("CMDECHO" . 0)
    		  ("MENUECHO" . 0)
    		  ("MENUCTL" . 0)
    		  ("MACROTRACE" . 0)
    		  ("OSMODE" . 0)
    		  ("SORTENTS" . 119)
    		  ("MODEMACRO" . ".")
    		  ("BLIPMODE" . 0)
    		  ("EXPERT" . 0)
    		  ("SNAPMODE" . 1)
    		  ("PLINEWID" . 0.0)
    		  ("ORTHOMODE" . 1)
    		  ("GRIDMODE" . 0)
    		  ("ELEVATION" . 0)
    		  ("THICKNESS" . 0)
    		  ("FILEDIA" . 0)
    		  ("FILLMODE" . 0)
    		  ("SPLFRAME" . 0)
    		  ("UNITMODE" . 0)
    		  ("TEXTEVAL" . 0)
    		  ("ATTDIA" . 0)
    		  ("AFLAGS" . 0)
    		  ("ATTREQ" . 1)
    		  ("ATTMODE" . 1)
    		  ("UCSICON" . 1)
    		  ("HIGHLIGHT" . 1)
    		  ("REGENMODE" . 1)
    		  ("COORDS" . 2)
    		  ("DRAGMODE" . 2)
    		  ("DIMZIN" . 1)
    		  ("PDMODE" . 0)
    		  ("CECOLOR" . "BYLAYER")
    		  ("CELTYPE" . "BYLAYER")
      (foreach v uan_var
        (setq m_v (cons (getvar (car v)) m_v)
    	  m_n (cons (car v) m_n)
        (setvar (car v) (cdr v))
      (princ (strcat (getvar "PLATFORM")
    		 " Release "
    		 (substr (ver) 18 2)
    		 " -  Convert To Anonymous Blocks ....\n"
    (PDot)
     ; ++++++++++++ Return Modes & Error
    (defun uan_rmd ()
      (setq *error* olderr)
      (mapcar 'setvar m_n m_v)
      (command "_.UNDO" "_END")
      (prin1)
    (PDot)
     ; ++++++++++++ Set And Start An Undo Group
    (defun SetUndo ()
      (and (zerop (getvar "UNDOCTL"))
           (command "_.UNDO" "_ALL")
      (and (= (logand (getvar "UNDOCTL") 2) 2)
           (command "_.UNDO" "_CONTROL" "_ALL")
      (and (= (logand (getvar "UNDOCTL") 8) 8)
      (command "_.UNDO" "_GROUP")
    (PDot)
     ; ++++++++++++ Get Entity Name
    (defun GetOne (/ st os)
      (setq	os (getvar "SNAPMODE")
    	s  nil
      (setvar "SNAPMODE" 0)
      (while (not st)
        (setq st (ssget))
      (while (> (sslength st) 1)
        (setq st nil)
        (princ "\nOnly 1 At A Time Please\n")
        (while (not st)
          (setq st (ssget))
      (setvar "SNAPMODE" os)
      (setq s (ssname st 0))
    (PDot)
     ; ++++++++++++ Convert An Anonymous Block To Named Block
    (defun UnAnon (b / tdef en ed bc bn bd in) ;Supply ename
      (setq	bn "TEMP1"
    	bc 1
      (while (tblsearch "BLOCK" bn)
        (setq bc (1+ bc)
    	  bn (strcat "TEMP" (itoa bc))
      (and (= (type B) 'ENAME)
           (setq bd	(entget B)
    	     in	(cdr (assoc 2 bd))
      (if (or (not bd)
    	  (not in)
    	  (/= "INSERT" (cdr (assoc 0 bd)))
    	  (/= "*U" (substr in 1 2))
    	  (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 4) 4)
    	  (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 16) 16)
    	  (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 32) 32)
          (princ "*** Not An Anonomymous Block *** ")
          (setq bn nil
    	    bc nil
    	    bd nil
    	    in nil
    	    b  nil
          (exit)
      (setq	tdef (tblsearch "BLOCK" in)
    	en   (cdr (assoc -2 tdef))
    	ed   (entget en)
      (entmake (list (cons 0 "BLOCK")
    		 (cons 2 bn)
    		 (cons 70 0)
    		 (cons 10 (cdr (assoc 10 tdef)))
      (entmake ed)
      (while (setq en (entnext en))
        (setq ed (entget en))
        (entmake ed)
      (entmake (list (cons 0 "ENDBLK")))
      (setq bd (subst (cons 2 bn) (assoc 2 bd) bd))
      (entmod bd)
      (entupd B)
      (princ (strcat "\n" bn))
    (PDot)
     ; ************ Main Program
    (defun uan_ (/ m_v m_n olderr uan_var s)
      (uan_smd)
      (GetOne)
      (UnAnon s)
      (uan_rmd)
    (defun c:UnAnonall (/ ss i)
      (setq	ss (ssget "X"
    		  (list	(cons 0 "INSERT")
    			(cons 67
    			      (if (= (getvar "TILEMODE") 1)
    				0
    				1
      (and ss
           (setq i (sslength ss))
           (while (not (minusp (setq i (1- i))))
    	 (setq en (ssname ss i))
    	 (if (= "*U" (substr (cdr (assoc 2 (entget en))) 1 2))
    	   (UnAnon en)
      (prin1)
    (PDot)
     ; ************ Load Program
    (defun C:UnAnon () (uan_))
    (if uan_
      (princ "\nUnAnon Loaded\n")
    (prin1)
     ; ================== End Program
  1. Explode anonymous block?
    By tzframpton in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Jun 2013, 02:34 pm
  2. A Weird Anonymous Block
    By BWells in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Feb 2010, 06:21 pm
  3. Is there a way to edit all blocks at once?
    By skipsophrenic in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Sep 2009, 09:20 pm
  4. Edit Blocks
    By frankie78 in forum AutoCAD Beginners' Area
    Last Post: 15th Aug 2008, 07:20 am
  5. anonymous dynamic block help
    By chulse in forum AutoCAD Drawing Management & Output
    Last Post: 11th Apr 2008, 01:46 pm
