Shift+letter shortcuts results typing capilal letter instead executing command
Hello, i found shortcuts starting with shift handy to use, so i based several shortcuts on it in previous 2012 version, as i updated to 2014 it doesnt work in same way, as i use any shortcut starting with shift it types a capital letter instead of executing command. Anyone have an idea what settings i should change to fix the problem?
I think you should be pressing the "ctrl" key for that.
I do it now, but is so uncomfortable and frustrating after 2 years habit, it was possible in earlier version so i think its just matter off settings
Welcome to CADTutor. :)
Sorry for asking, but you are pushing them at the same time, right?
Thank you, i press letter while holding shift same way i do with ctrl.
