Can´t seem to get it right with rendering in autocad, need help
miroslav_s
Hi,
I reallydon´t get it. What am I doing wrong? I get totally wrong result when rendering.I put two links so that you can see what I mean. The first link(http://prntscr.com/3sureb ) is showing theobject (car) as it looks like in autocad when I work with it and here it lookjust fine. As materials I used PLASTIC LATEX (http://prntscr.com/3sv24a) and PLASTIC RED ON (http://prntscr.com/3sv2bq) . The reason Iused high transparency for material Latex is so that the brakingsystem on thecar can be seen better. BUT as you can see the result is very bad http://prntscr.com/3suyky
So what amI doing wrong? I tried to upload the file here but that didn´t work so I put the download link for those who want to take a look at the file : https://dl.dropboxusercontent.com/u/8906158/mojdeo.dwg
PS: I tried with two different computers and got the same result
Thanks in advance and best regards to you all
Miro
Try adjusting the refraction for the material on the car body.
maybe 1.0-air?
Edited by The Ninja Style
First ofall thank you for helping me. You can see on this links below what I´m trying toachieve. I made those Changes like you said. Theresult is much better but still not the way I want it. http://prntscr.com/3tdthz
Why can´tthe result be like in autocad MODEL : http://prntscr.com/3tdtzu
THIS ISWHAT I WANT IT TO LOOK LIKE.It is from a website http://prntscr.com/3tduwm
If you haveany more suggestions please tell me. Best regards and thank you for trying
Miro
Yes !!! I figuredit out finally what the problem was. Well, I´m a little ashamed to tell youabout my big mistake! I adjusted render quality to 5, set it to PRESENTATION inRender Presets Manager and in Adjust Rendered Exposure set the Brightness to 40and the result got finally much better. Need to do some more testing to get itright but finally. Thank you both for helping me BUT I did I big mistake byforgetting to set the render to PRESENTATION
Thanks again!
Bestregards to you both!
Miro
