miroslav_s Posted June 14, 2014 Share Posted June 14, 2014 Hi, I reallydon´t get it. What am I doing wrong? I get totally wrong result when rendering.I put two links so that you can see what I mean. The first link(http://prntscr.com/3sureb ) is showing theobject (car) as it looks like in autocad when I work with it and here it lookjust fine. As materials I used PLASTIC LATEX (http://prntscr.com/3sv24a) and PLASTIC RED ON (http://prntscr.com/3sv2bq) . The reason Iused high transparency for material Latex is so that the brakingsystem on thecar can be seen better. BUT as you can see the result is very bad http://prntscr.com/3suyky So what amI doing wrong? I tried to upload the file here but that didn´t work so I put the download link for those who want to take a look at the file : https://dl.dropboxusercontent.com/u/8906158/mojdeo.dwg PS: I tried with two different computers and got the same result Thanks in advance and best regards to you all Miro Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted June 15, 2014 Author Share Posted June 15, 2014 Nothing? Any help would be great...Been trying all day to fix it but with no luck Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 15, 2014 Share Posted June 15, 2014 I'm not at my home computer today, but if I have some time tomorrow I'll take a look at your file. Also, I've moved your question to the Autocad 3D Modeling & Rendering section of the forum. Quote Link to comment Share on other sites More sharing options...
The Ninja Style Posted June 16, 2014 Share Posted June 16, 2014 (edited) Try adjusting the refraction for the material on the car body. maybe 1.0-air? Edited June 16, 2014 by The Ninja Style Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted June 16, 2014 Author Share Posted June 16, 2014 First ofall thank you for helping me. You can see on this links below what I´m trying toachieve. I made those Changes like you said. Theresult is much better but still not the way I want it. http://prntscr.com/3tdthz Why can´tthe result be like in autocad MODEL : http://prntscr.com/3tdtzu THIS ISWHAT I WANT IT TO LOOK LIKE.It is from a website http://prntscr.com/3tduwm If you haveany more suggestions please tell me. Best regards and thank you for trying Miro Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted June 16, 2014 Author Share Posted June 16, 2014 Yes !!! I figuredit out finally what the problem was. Well, I´m a little ashamed to tell youabout my big mistake! I adjusted render quality to 5, set it to PRESENTATION inRender Presets Manager and in Adjust Rendered Exposure set the Brightness to 40and the result got finally much better. Need to do some more testing to get itright but finally. Thank you both for helping me BUT I did I big mistake byforgetting to set the render to PRESENTATION Thanks again! Bestregards to you both! Miro Quote Link to comment Share on other sites More sharing options...
