jarr3tt88 Posted June 16, 2014 Share Posted June 16, 2014 I would love to know if there was a way to view a clip frame when selecting a clipped object. I currently have FRAME = 0 FRAMESELECTION = 0 XCLIPFRAME = 0 Is it possible to have the clip boundary appear when selecting the object that is XCLIPFRAME = 1 THEN go back to XCLIPFRAME = 0 when done editing the boundary or inverting the clip? I have created custom commands in the meantime to turn on the frames and turn off the frames, but if there were some system variables I can play with to make the above happen I would be happy! Heres the marco codes I'm using for the custom commands Clip Frame Off ^C^C_xclipframe;0; Clip Frame On ^C^C_xclipframe;1; Also if this is the case it can be done, could it also be done for wipeouts? I have done the similar above for wipeouts also. Wipeout Frame On ^C^C_wipeout;f;on Wipeout Frame Off ^C^C_wipeout;f;off Any help is appreciated, thank you in advance! Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted June 17, 2014 Author Share Posted June 17, 2014 No suggestions? Steven, Dana?? Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 17, 2014 Share Posted June 17, 2014 And if you have XCLIPFRAME=0, FRAME=0 and FRAMESELECTION=1. Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted June 17, 2014 Author Share Posted June 17, 2014 Thanks steven! No that doesn't work. Well it does, but then I could select the frame/object when selecting other objects. Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 17, 2014 Share Posted June 17, 2014 OK, so when do you need it on and when do you need it off, but I think what you are doing now is probably the easiest way (toggling the values) Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted June 17, 2014 Author Share Posted June 17, 2014 Turning on will only be when I need to adjust the clip frame or invert it. Then once I do that it would be off again. I figured it would be easiest to just be able to click the object to get the boundary to show like frame selection, but I don't want to be picking the clipped object. I guess I'll just leave it with the two buttons, unless anyone else has another idea. Thanks buddy Quote Link to comment Share on other sites More sharing options...
