Results 1 to 7 of 7
    Forum Newbie
    Inventor 2015
    Jun 2014
    4
    Unhappy "Unfolding" a circular surface to a planar surface ?
    Hi,
    I have a problem I can't seem to solve
    I have two pipes, installed eccentrically. The pipes will be perforated (made holes in) perpendicularly to the inner pipe axis. The perforations have a known phasing and density that will be true for the inner pipe. But due to the eccentricity of the pipes, the holes in the outer pipe will be random.
    What I want do do is to use Inventor to "unfold" the outer/larger pipe surface OD, to trace the holes down to a flat plane or surface. Then the plan is to print out this flat surface on a paper, wrap it aroud the pipe and drill the holes manually.
    Please find attached pdf that will help you understand my frustration.
    Can you help me with this? Please ask if you have any questions.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Attach your attempt (*.ipt files) here.
    Do you need the flat pattern for the inside pipe or just for the outside?
    I would do as multi-body surfaces trimming the outside pipe and then Thicken (if only need outside).
    If need inside too, I would Derive Components and then Thicken.
    There is one additional problem to be concerned with, but I will wait for your attempt.
    Forum Newbie
    Inventor 2015
    Jun 2014
    4
    Thank you very much for your fast reply!
    I have made a simplified version of it now, so let's stick to this at first (please find attached). If we can do it with this part, it should be the same with the others.
    To answer your question:
    What I want is the pattern on the outer surface (OD) of the outer pipe.
    In the meanwhile, I'll try your advice.
    Forum Newbie
    Inventor 2015
    Jun 2014
    4
    I cannot quite see how your method would work.. ? By using thicken or offset, All I get is a new cylindical shape/surface. I need the cylindrical surface to be bendt down to a flat surface.. I am experimenting with the bend function now. I am hoping that I can split the pipe in halvf, and bend each half down to a flat plate. But it seems hard to accomplish. I dont think Inventor likes bending shapes that are already bendt.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by markusiuell View Post
    ... I am experimenting with the bend function now.....I dont think Inventor likes bending shapes that are already bendt.
    I never had any intention of using the Bend feature.
    Only took a fraction of a second for Inventor to flatten the part you attached.
    Was this the inside tube or the outside tube that you attached? (I assume by the regular pattern that it is actually the inside tube.)
  6. #6
    Forum Newbie
    Inventor 2015
    Jun 2014
    4
    Thanks a lot! I will try again when Im back in work tomorrow. Seems easy, but I do not have very much experience with the sheet-metal function (if that is what you used?) and would be very glad if you could supplement me with a little step-by-step tutorial, if you have the time
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    There are some Sheet Metal tutorials in the Inventor Help.
    Easy enough for the inside tube, but there is a trick to getting those holes on the outside tube lined up with the inside tube.
  1. 3D Surface - Visual Style issue while in "Drive" mode
    By tcaruso in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Oct 2012, 06:54 pm
  2. surface -> planar surface
    By frunza_samuel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Jul 2012, 12:20 pm
  3. Converting a "region" of planar surfaces to 3D solid
    By Alex0856 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Apr 2010, 06:06 pm
  4. Apply a "skin" or surface to a skeleton of paralle
    By ParkLife in forum AutoCAD General
    Last Post: 20th Jun 2006, 01:00 pm
  5. creating a surface with "rulesurf" command
    By tk2 in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Aug 2005, 08:06 pm
Tags for this Thread
