kingdaddy Posted June 18, 2014 Share Posted June 18, 2014 I am getting a hardware upgrade and the new computer will be running the 64 bit version of 2015 instead of the current 32 bit. I have done a lot of customizing already with the CUI, Command Aliases and Tool Palettes. Is there an easy way to save all my settings and workspace so I can migrate them to a new computer? Quote Link to comment Share on other sites More sharing options...
zaphod Posted June 18, 2014 Share Posted June 18, 2014 here is the setting in 2013, should be similar Quote Link to comment Share on other sites More sharing options...
kingdaddy Posted June 18, 2014 Author Share Posted June 18, 2014 Does this take care of everything like my new and edited Aliases and sys variables? Quote Link to comment Share on other sites More sharing options...
zaphod Posted June 18, 2014 Share Posted June 18, 2014 No, nor will it automatically bring up custom tools / toolbars, that is done though the custom user interface, this just gets you some help. I think you will have to change the sys variables manually. 42 x 2 Quote Link to comment Share on other sites More sharing options...
kingdaddy Posted June 18, 2014 Author Share Posted June 18, 2014 Thank You Mr Beeblebrox. Looks like I'll just have to redo most everything over again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 18, 2014 Share Posted June 18, 2014 Commonly customized files include: linetypes (.LIN), hatch patterns (.PAT), command aliases (.PGP), tool palettes (.ATC), and profiles (.ARG). Some of these, but not all, may be saved in a zip file via the Migrate Custom Settings > Export AutoCAD 2015 Settings feature found by clicking on the Start Button and looking under All Programs > AutoDesk. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 18, 2014 Share Posted June 18, 2014 Yep... Start > Programs > Autodesk > AutoCADxxx > Migrate custom settings > Export AutoCADxxxx settings Also, you can have AutoCAD360 automatically sync your settings via the cloud if you're so inclined More... Quote Link to comment Share on other sites More sharing options...
kingdaddy Posted June 19, 2014 Author Share Posted June 19, 2014 Thanks guys, all backed up now:D Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 19, 2014 Share Posted June 19, 2014 Like above we have multiple pc's so have had to do this lots Like Remark use the profile option and create a profile with a new name and export it giving a ARG. Go to new box start autocad as normal go to profile load your new profile, close autocad. Edit the autocad desktop icon, we make a copy and push old one to safe directory, in the icon properties the end will be edited to /p your new profile name. Click on icon should work. We also have a new main customisation file in a common directory, only problem is it will not have say 2015 commands so we make all our extra customistation as partial menus then you can load and save on 1 box the new Main customisation menu mynew2015.cuix and copy to others with new version commands intact. Quote Link to comment Share on other sites More sharing options...
