Results 1 to 5 of 5
    Forum Newbie
    minja's Computer Details
    Windows 7
    Architectural
    AutoCAD 2013
    Jun 2014
    Serbia
    2
    Unhappy How to create a surface?
    I have been searching for a very long time and i hope you can help me this way cause i found nothing. The thing is, i have a polyline and set its thickness but i need something like 3DFACE which can cover those open areas on the bottom and top. Nothing ever worked, except for dividing it into million pieces and applying 3dface/loft for each, lol
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Only need 4 curves and Loft.
    Attach your dwg here.
    Forum Newbie
    Windows 7
    Architectural
    AutoCAD 2013
    Jun 2014
    Serbia
    2
    Thanks for quick response. Here's my .dwg file. I guess it's easy to make flat surface on any polyline whether it's rectangular or like this one. I'm going to use this a lot, so are there any specific commands?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    How did you create that geometry?
    Why are there 10 million points for such simple geometry?
    I would create with simple lines and arcs.
    Join each of the longer sides.
    This would leave you with four sides.
    Loft between the two shorter sides using the longer sides as the guide curves.
    Use the Thicken command if you want a solid.
  5. #5
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    357
    Default Use Region or SURFNETWORK
    Since the shape is 2D why not make it a region? I would first recreate the shape using splines and then the region command. See the attached file. Be sure to use Conceptual for the Visual Style so you can see the result. You can also create a surface using SURFNETWORK. Here is the dialog with my comments (do this after you have made the outline of the shape with 4 splines:
    Command: _SURFNETWORK
    Select curves or surface edges in first direction:1 found <-- select the long side near the bottom
    Select curves or surface edges in first direction:1 found, 2 total <-- select the other long side near the bottom
    Select curves or surface edges in first direction: <-- ENTER
    Select curves or surface edges in second direction:1 found<-- select the short side near the left
    Select curves or surface edges in second direction:1 found, 2 total <-- select the other short side near the left
    Select curves or surface edges in second direction: <-- ENTER
    floor2.dwg
  1. About create contours from a surface.
    By jcaz15 in forum Civil 3D & LDD
    Last Post: 30th Sep 2013, 09:34 am
  2. Cannot Create a Surface - LDD 2007
    By SaveLDD in forum Civil 3D & LDD
    Last Post: 12th Sep 2013, 12:28 pm
  3. create cut fill surface from excisting surface in Civil 3d
    By smileyours in forum Civil 3D & LDD
    Last Post: 1st Mar 2013, 09:26 pm
  4. Help to create surface
    By kama1005 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Jun 2010, 11:34 pm
  5. need to create a flat surface on curved surface
    By harley558 in forum Autodesk Inventor
    Last Post: 23rd Mar 2010, 05:28 pm
Tags for this Thread
