raymarcher Posted June 20, 2014 Share Posted June 20, 2014 I want to batch displace 150 DWG files and save them with the suffix _displace. Here is my script, I am stuck with the suffix part. Anyone can help? Also, am I choosing the right tools to batch displace DWG's? As I understood a script and scriptpro is optimal since it does not open AutoCAD itself. MOVE ALL ENTER ENTER 10,10,0 ENTER ENTER SAVEAS ENTER ENTER Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 21, 2014 Share Posted June 21, 2014 Wheres is your Open dwg1 at start A move requires two pts move all blankline 0,0,0 10,10,0 Savesas c:\\myjobs\project 52\design_1 close A blank line is a ENTER in a script do not add a space this will give two ENTER You need to watch closer the manual steps write them down, you may need also at start filedia 0 this turns off the dialouge box entry for files then filedia 1 at end. Check also _saveas Quote Link to comment Share on other sites More sharing options...
