Results 1 to 5 of 5
    Full Member Nobull84's Avatar
    AutoCAD 2011
    Nov 2013
    86
    Default Same views in layouts
    I have created a view to zoom to my titleblock and plot stamp so that I may check revision dates. I then put this to a macro for easy access to the view (I keep the ribbon closed for maximum screen size most of the time). It seems that these saved views are only saved in the current drawing and I would need to save a view for each drawing file. This can be cumbersome for many drawings. Is there an easier way to view a certain area in paperspace? Or is there a lisp out there to create a saved view in multiple drawing files?
    Thanks for your time,
    -Nobull
    P.S. I also just realized this saved view not only goes to certain position but also switches to that specific layout. Is there a way to just save a position in paperspace to use on any layout?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    How about the humble zoom command, this zooms to a prefixed area
    Code:
    ^C^C_Z;100,100;150,150;
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    Or if your Titleblock can vary in size and position then draw a rectangle around it and create a group, then you can zoom to an object with the group option
    AutoCAD 2011
    Nov 2013
    86
    Quote Originally Posted by steven-g View Post
    Code:
    Sometimes I guess I overthink things but you are right, the simple zoom feature works fine. I ended up recording a macro where I used: "Z", "Object", select my titleblock and plot stamp. Renamed it "VV". And a new command is born. Thanks for the new pair of eyes.
    -Nobull
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Named views are saved until purged.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Replies: 0
    Last Post: 3rd Jun 2011, 07:10 pm
  2. Replies: 10
    Last Post: 14th Sep 2010, 10:24 am
  3. Replies: 2
    Last Post: 13th Jul 2010, 05:38 pm
  4. Various isometric views/drawing views
    By WagglyFawn in forum SolidWorks
    Last Post: 25th Nov 2009, 09:41 pm
  5. SSM sheet views and model views
    By chelsea1307 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Dec 2008, 09:37 am
Tags for this Thread
