Sheet Set Manager Error: Unable to save settings to...
jdmisoulis
This issue is happening to everyone who has tried so far. We are trying to select "manage page setups" through sheet set manager and receive an error saying:
K:\\...\400_details.dwt (file name shortened). Please check your access to this file and to its directory or network location and try again.
I have checked with our IT guy and have found that the permissions are correct (we can all read/write to the directory and file). Any idea what the issue is?
I am using AutoCAD 2012, others are using 2014.
  • 1 month later...
Hello jdmisoulis,
Did you find a solution to this one? I am having the exact same problem. It appears to have occurred when my office upgraded our server and migrated the location some files.
I can actually print from sheet sets using previously made overrides and also PDF etc. from the SSM. My issue is when trying to open the Manage Page Setups in order to add a plot stamp to a PDF file.
