Remove all degrees of freedom
Jake8090
Hello everybody. I will try to upload an assembly file with a wind turbine blade in two parts. My problem is that I have constrained the top edge with a mate flush constraint and the connecting faces with a mate constraint, so far so good, I was able to position the top section by sliding it along. However I would like to lock it in its correct position. Is there any method or constraint that will remove the remaining degrees of freedom.
Sorry had to upload the ipt files as I could not find how to zip the assembly file.Best Regards Jake8090
Blade Base WT.ipt
Blade Top WT.ipt
Mate Flush the corresponding part origin planes.
Looks like you will only need one of those Mate Flush (YZ Plane) constraints from your description.
