Help with flex part
diegsn
  • 2 weeks later...
You should use the sheet metal tool for this as opposed to solid modelling.
Draw out the contour, add material thickness, unfold and trim out the "v" shape then fold back to the original shape.
(sorry for the poor example, I only had a few minutes to do it)
Thank you very much, I will try to do it like you say
For this example I finally use the Wrap tool, but this method is not useful for other pieces
