ripuz Posted June 25, 2014 Share Posted June 25, 2014 Hi! I have a problem with acad2012.lsp... it will always load on every drawing. At the moment I have moved the original files acad2012.lsp and acad2012doc.lsp to a location that AutoCAD doesn´t find. Then I put the four following files in the support folder (C:\Program Files\Autodesk\AutoCAD 2012 - English\Support): acad2012.lsp acad.lsp acad2012doc.lsp acaddoc.lsp The files doesn´t contain anything other than a single princ command which say: acad2012.lsp loaded! acad.lsp loaded! acad2012doc.lsp loaded! acaddoc.lsp loaded! When AutoCAD is started all files are executed in the following order: acad2012.lsp acad.lsp acad2012doc.lsp acaddoc.lsp This far everything is okay... but when I open a new drawing the following is in the text window: acad2012.lsp loaded! acad2012doc.lsp loaded! acaddoc.lsp loaded! I expected that only acad2012doc and acaddoc should be executed since the ACADLSPASDOC variable is set to 0. Shouldn´t acad2012.lsp and acad.lsp go hand in hand, either be none or it will load both? Is there some other setting I don´t know about? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 25, 2014 Share Posted June 25, 2014 The auto-loaders acad20xx.lsp and acad20xxdoc.lsp were reserved by system, so is better not to affect them. For this reason you cannot rely on how AutoCAD access/manage them. Quote Link to comment Share on other sites More sharing options...
ripuz Posted June 25, 2014 Author Share Posted June 25, 2014 Okay you are right, so I put the original files back and just entered the princ at the bottom of them to verify if and when they are loaded. The same result however. The auto-loaders acad20xx.lsp and acad20xxdoc.lsp were reserved by system, so is better not to affect them. For this reason you cannot rely on how AutoCAD access/manage them. Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 25, 2014 Share Posted June 25, 2014 Not sure what difference make how AutoCAD is accessing its internal files. For your custom tools use acaddoc.lsp and/or acad.lsp (control behavior of latest by ACADLSPASDOC system variable). Quote Link to comment Share on other sites More sharing options...
ripuz Posted August 18, 2014 Author Share Posted August 18, 2014 I made a new installation of AutoCAD 2012 and acad2012.lsp is still loaded into every drawing. Either AutoCAD needs it loaded twice for some reason or some programmer made a misstake. Anyhow it´s nothing to do about it. End of story! Quote Link to comment Share on other sites More sharing options...
