NC2010 Posted June 27, 2014 Share Posted June 27, 2014 I am getting the following ERROR message when starting AutoCAD 2011LT ''Unable to load profile file, some profile information saved in last session may not be restored'' I followed the advice on another forum site... What a waste of time, uninstalled and reinstalled and guess what = same problem any help welcome Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 27, 2014 Share Posted June 27, 2014 I thought LT did not use Profiles. What is the original source of the file (.arg?) that you tried to load? Quote Link to comment Share on other sites More sharing options...
NC2010 Posted June 27, 2014 Author Share Posted June 27, 2014 I thought LT did not use Profiles. What is the original source of the file (.arg?) that you tried to load? This is the message I get when I launch autocad Quote Link to comment Share on other sites More sharing options...
Dana W Posted June 28, 2014 Share Posted June 28, 2014 Apparently AutoCad LT uses the same error messages as full AutoCad. LT does not have modifiable "USER" profiles, but it does have a single default profile. The customization files such as saved workspaces, tool bars, line types, hatches, and anything like that, that can be customized is considered part of the "profile". These files are located in the enu folder of the support path. Did you recently move to another computer? It could be one or more of the following files that needs to be located or replaced with a backup. You'll have to save as... the png to read it. That's as big as I can make it. Quote Link to comment Share on other sites More sharing options...
Dana W Posted June 28, 2014 Share Posted June 28, 2014 I am getting the following ERROR message when starting AutoCAD 2011LT ''Unable to load profile file, some profile information saved in last session may not be restored'' I followed the advice on another forum site... What a waste of time, uninstalled and reinstalled and guess what = same problem any help welcome Did you follow the procedure outlined by AutoDesk to do a clean uninstall and re-install? If not then it was a waste of time indeed. Have you tried going to Windows Control panel, Programs and features and do a Repair on the AutoCad installation? Quote Link to comment Share on other sites More sharing options...
