inlet pipe of radius 160 (ILRU160)
dme
Hi
I'm new to AutoCAD. I'm trying to make a inlet pipe of radius 160 (ILRU160)
I have been trying with two circles and an arc and the use the command LOFT. Is this the right way?
Please give me some ideas.
Thanks
Have you tried a pline with c/l radius draw a circle = dia pipe, use rotate3d to rotate circle sq to end of pline use a 3d view to see whats going on vpoint 1,1,1 then Extrude circle path.
