wimal Posted June 30, 2014 Share Posted June 30, 2014 When I load lisp files to autocad 2014. allways a message display asking to to confirm to trust the file. How can I stop that. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2014 Share Posted June 30, 2014 Courtesy of the CADforum: You can disable this security protection with the variable SECURELOAD (to 0) but the right and safe way of suppressing the warning dialog is adding the folders with your add-on applications to the list of trusted locations (folder paths). You can do this using the variable TRUSTEDPATHS or more conveniently using Options > Files > Trusted Locations. Quote Link to comment Share on other sites More sharing options...
wimal Posted June 30, 2014 Author Share Posted June 30, 2014 Ok Thanks. I will use it. Quote Link to comment Share on other sites More sharing options...
