ralcala55 Posted July 1, 2014 Share Posted July 1, 2014 When I select line the line command to draw a line and then use the shortcut menu to use an object snap mode, endpoint or mid for instance, the pointer will jump up and over or to the other display. Any ideas? Is this a driver issue? If I use an object snap mode from a tool bar I don't have an issue, but it is more convenient at times to use the shortcut (right mouse button) to select the object snap mode. Thank you, ralcala55 Quote Link to comment Share on other sites More sharing options...
kizaerf Posted July 15, 2014 Share Posted July 15, 2014 make sure grid snap is turned off (at the bottom of the screen, I would upload a pic but i don't know how to ) its usually checked by default in a new drawing (pain in the butt) Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 15, 2014 Share Posted July 15, 2014 make sure grid snap is turned off (at the bottom of the screen, I would upload a pic but i don't know how to ) its usually checked by default in a new drawing (pain in the butt)It's in drafting settings. Command dsettings >> Snap & Grid tab. It's not a default in new drawings, it is a system variable that will stay off once it is turned off, until messed with again. It may be a workspace property that won't take permanently unless you are saving your workspace changes. Quote Link to comment Share on other sites More sharing options...
