basty Posted July 2, 2014 Share Posted July 2, 2014 Do someone here can create a technical illustration in perspective drawing (one, two, or three-point perspective drawing) such as below image using AutoCAD or Adobe Illustrator? Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 2, 2014 Share Posted July 2, 2014 Are you hiring? Quote Link to comment Share on other sites More sharing options...
basty Posted July 5, 2014 Author Share Posted July 5, 2014 Are you hiring? can you create technical illustration such as above? Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 5, 2014 Share Posted July 5, 2014 I wouldn't have thought creating the perspective would be too much trouble (just a lot of work) drawing each items perspective on it's own layer, though I do think full autocad has a perspective option, the thing that I would find nearly impossible is the "artistic" part how would you decide which parts to show and how much fading to use on others, and I think that would be better suited to either a photo or rendering program. Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 5, 2014 Share Posted July 5, 2014 can you create technical illustration such as above?Are you paying for the work or what? Are you hiring someone to do it? On second thought, I withdraw my inquiry. The dirth of information is dismaying. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 5, 2014 Share Posted July 5, 2014 .... The dirth of information is dismaying. http://www.cadtutor.net/forum/search.php?searchid=2437116 Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 5, 2014 Share Posted July 5, 2014 http://www.cadtutor.net/forum/search.php?searchid=2437116Let me rephrase that. The failure to answer my direct questions is dismaying. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 5, 2014 Share Posted July 5, 2014 The image attached is most definitely a hand drawing. If it were done using digital tools, it was done so with a Wacom drawing tablet or something comparable. Illustrator/Photoshop can produce exactly the image above. You can certainly do it in AutoCAD but it would be an undertaking, and would still need Photohop for post image processing. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 5, 2014 Share Posted July 5, 2014 It could be done in a 3D program and rendered using a toon shader to get that illustration look. You would need to render the car body separate from the internal mechanical components, then overlay in Photoshop and mask out the areas you want to show through. I would not attempt this in Autocad though. And as Dana asked, are you hiriing? This would be a pretty big job. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 5, 2014 Share Posted July 5, 2014 This would be a pretty big job.It's a big job indeed if it were modeled in 3D and rendered. A professional illustrator could take some digital pictures and put them on a layer in their software of choice and fade them to trace over it with ease. I've seen YouTube videos of illustrators who can recreate images like this in no time. I've been on the verge of buying myself a Wacom tablet for quite some time and just haven't bit the bullet yet, so I've been doing my research. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 5, 2014 Share Posted July 5, 2014 I've moved the Wacom tablet discussion here: http://www.cadtutor.net/forum/showthread.php?87516-Wacom-Tablet Quote Link to comment Share on other sites More sharing options...
