mirvakili Posted July 3, 2014 Share Posted July 3, 2014 I want to extrude all circles in my dwg file, but some of them don't get extrude. how can I extrude all circles. my dwg file is attached. Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 3, 2014 Share Posted July 3, 2014 Those that haven't extruded are inside a block, either explode the blocks or open the block editor and extrude the circle from inside the editor (you only need do that for the one block and all the blocks will change). I use LT so I'm not sure how the extrude command works, but it should work inside the block editor. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 3, 2014 Share Posted July 3, 2014 As steven-g suggested extrude the circle that is part of a block inside the block editor and it will display properly when you are back in your drawing. Quote Link to comment Share on other sites More sharing options...
mirvakili Posted July 4, 2014 Author Share Posted July 4, 2014 thanks so much Quote Link to comment Share on other sites More sharing options...
