rtos precision misbehaving.
JamCAD
I'm not getting the expected result for rtos. It is removing trailing zeros even if I "force" a precision???
(rtos 380.00 2 2) returns "380" not "380.00". I'm thinking it must be a system variable?
Explore DIMZIN sysvar.
Set the System Variable dimzin to zero or set it to zero and reset it back in your routine .
Thanks all. I was coding on my laptop while traveling so didn't have normal access to my research options (I.e. Google). Posted on my phone thinking I would get the quick response I did :-). Lee, later after dimzin was mentioned I googled "rtos dimzin". I will give you three guesses as to the first page I visited...
