obscurejack Posted July 6, 2014 Share Posted July 6, 2014 Hello! I'm a noob in rhino and I found some problems by making a polysurface solid: my problem is that I have two elements: a sphere and a twisted pyramid, joined by boolean union which I can't offset to add an internal thicken. when I do it (with "solid" option activated) it just creates a polysurface inside it, without creating an emptiness in it. I can't even make a boolean difference, boolean 2 objects or neither a solid subtraction that work with polysurfaces which surfaces do not intersect each other. Indeed, when I make a section to see how it is inside there's no hole but only the sectioned edges of the offset polysurf. H E L P!!!! Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 7, 2014 Share Posted July 7, 2014 Rhino has a surface focus. Thus, some of the concepts that pertain to "Solids" in other software applications are not present in Rhino. One such concept is internal hollows - or, put another way - surfaces/surface incorporation without direct connection. The typical way to deal with this is to add a direct connection. See attached image. I was able to hollow out that figure by providing a minimal direct connection in an inconspicuous spot. Quote Link to comment Share on other sites More sharing options...
obscurejack Posted July 7, 2014 Author Share Posted July 7, 2014 thank you very much, I already solved the problem with the same tecnique but in a different way ^^ Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 7, 2014 Share Posted July 7, 2014 . . . . I already solved the problem . . . . ^^ That's all that matters. Quote Link to comment Share on other sites More sharing options...
