callvey Posted July 9, 2014 Share Posted July 9, 2014 Hi, Is there a way to change the resolution of the drawing when zooming in in paperspace? not in a viewport.? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Tiger Posted July 9, 2014 Share Posted July 9, 2014 REGEN? Or REGENALL? Does it look pixelated when you print? Quote Link to comment Share on other sites More sharing options...
callvey Posted July 9, 2014 Author Share Posted July 9, 2014 No, REGEN doesnt work and no i havnt tried to print it. Quote Link to comment Share on other sites More sharing options...
Tiger Posted July 9, 2014 Share Posted July 9, 2014 Then I don't know. I think that this has been asked before, and I don't think that there was a solution then. Unless upping the VIEWRES-variable helps for you. I just did a test in my 2015-version and it is smoother lines there then in 2014 - so better times are coming. Quote Link to comment Share on other sites More sharing options...
callvey Posted July 9, 2014 Author Share Posted July 9, 2014 Thanks for trying, I know there is a setting somewhere that stops the drawing in paperspace from looking pixelated while zooming in. It basically looks exactly as it does in model space when zooming. Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 9, 2014 Share Posted July 9, 2014 Viewres is the global control for both model and paperspace. Either enter a value at the command prompt, or change it on the options dialog, display tab. If your viewres is already set to a value of 15000 or higher, you are probably bumping up against the physical limits of your monitor hardware. Now, if you have lineweight display turned on, that will make paperspace look much worse than modelspace since the lines are displayed much fatter in paperspace with that turned on. Quote Link to comment Share on other sites More sharing options...
callvey Posted July 9, 2014 Author Share Posted July 9, 2014 I didn't even think about that....Lineweight!! Thats was it, thank you very much Dana Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 9, 2014 Share Posted July 9, 2014 I didn't even think about that....Lineweight!! Thats was it, thank you very much Dana :facepalm:Glad we could help. Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted July 10, 2014 Share Posted July 10, 2014 But "displayed much fatter in paper space" isn't pixelated is it ? lol Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 10, 2014 Share Posted July 10, 2014 But "displayed much fatter in paper space" isn't pixelated is it ? lol Dowd, Elwood P. Now he was pixelated. "Much Fatter" is one of those esoteric technical terms that only the most experienced of us truly understand. Quote Link to comment Share on other sites More sharing options...
