RobinEloquence Posted July 9, 2014 Share Posted July 9, 2014 Hello! I'm trying to embed an image into a title block (not as a reference). The only information I can find to do this requires I use the command PASTESPEC. This results in an 'unknown command' notification. What am I missing? I'm using AutoCad 2014 on a Mac OS 10.9.3. The primary reason I want to embed the image is because I want to remove the image frame. I've tried to remove it by setting both IMAGEFRAME and FRAME to 0 and 2 in the original title block dwg which seems to work, but when I insert the title block into my drawing the image frame reappears. I set IMAGEFRAME and FRAME to both 0 and 2 in this drawing as well but it's still there. Any help with this issue would be stupendous!! Quote Link to comment Share on other sites More sharing options...
gazza_au Posted July 9, 2014 Share Posted July 9, 2014 Not at a comp now but can you put frame as a layer that won't print such as your viewport one, or draw one over the top and use draw order to stop it showing up when printing? Quote Link to comment Share on other sites More sharing options...
hoss Posted July 10, 2014 Share Posted July 10, 2014 Have you tried changing the setting for OLEFRAME Quote Link to comment Share on other sites More sharing options...
