Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Full Member
    AutoCAD 2014
    Jul 2014
    57
    Quote Originally Posted by Dadgad View Post
    You won't find any OOTB way to do that, although I would be surprised if Tharwat doesn't come up with something for you.
    You could of course do this with a simple spline defined leader, and an unattached mtext. I use those myself, but with the arrow
    attached to the item being referenced, rather than the test note, as is the norm.
    When done that way, I think they look better, as the mtext position is adjustable to one's liking, and not dictated by the landing attachment position choices available in the multileader definition dialogue.
    Ok, I am trying to use the one function in order to draw the splined leader and to have that R annotation. Any syntax in LISP that allows you to do that?
  2. #12
    Full Member
    AutoCAD 2014
    Jul 2014
    57
    Quote Originally Posted by Tharwat View Post
    Go down to the right side hand and press to Go advanced when you 'd like to reply to thread then after that from the attachment button you can add images or drawings according to file formats that are available in the list .
    Upload a drawing with your desired result with the Mleader Style that you are using , which is style_25 to be able to reply to your request .
    This is my desired result. Note where the annotation "R" is. What I have atm is the R at the landing but I want to have the R at the arrowhead as per this image.
  1. Set MLeader to Existing MLeader Style via LISP
    By parkerdepriest in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2017, 09:13 am
  2. Mleader, Mtext and AutoLisp
    By guitarguy1685 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Aug 2011, 03:26 pm
  3. Mleader Dialog Box in a Lisp
    By TheyCallMeJohn in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jan 2011, 07:09 pm
  4. Mleader with predifined, auto text or mtext?
    By Michael83 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Oct 2010, 09:27 pm
  5. help! mleader/qleader's text or mtext rotation.
    By ODEY in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th May 2010, 12:52 am
Tags for this Thread
