Results 1 to 7 of 7
Thread: 3d solid colors
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    4
    Default 3d solid colors
    Hi!
    How can I set different colors for 3d solid cube?
    (I don't want to explode, because I will lose the height/width/length data, from the properties window.)
    Thanks!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Welcome to the Forum, Nagygabor679!
    Please check if the SOLIDEDIT command with Edge --> Color options is what you were looking for.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    ...or Face and coLor
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    ...or hold Ctrl+Pick, which isolates the the individual Face. This is also true for all sub-object elements, such as Face, Vertex, or Edge.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  5. #5
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    4
    Thanks for everybody! The Ctrl+Pick is the most simple solution.
  6. #6
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    4
    Oops! After that, the height/width/length properties missing from Properties window. How can I set the 3d solid height/width/length now?
    How can I see the set the 3d solid height/width/length now (by keyboard)?
  7. #7
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    In AutoCAD, only 3D primitive objects have editable height/width/length/radius/etc properties. After manually applying property overrides to individual faces, the 3D solid is no longer a "primitive" object so you have to use Grips or the SOLIDEDIT tools to modify the object dimensions.
  1. Colors plotting as colors, despite ctb set to black.
    By Big Mike in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jun 2014, 08:09 pm
  2. Replies: 2
    Last Post: 28th Feb 2012, 02:03 pm
  3. AutoCAD: Best practice: fill hole in solid, remove region from solid
    By MichaelBrenden in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Nov 2010, 08:31 pm
  4. Change pastel colors to alternative colors by layer & elements & blocks
    By deucer in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2010, 06:13 pm
  5. Solid colors are hidden when printing.
    By uhcafigdc in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Apr 2009, 08:40 am
