nagygabor679 Posted July 11, 2014 Share Posted July 11, 2014 Hi! How can I set different colors for 3d solid cube? (I don't want to explode, because I will lose the height/width/length data, from the properties window.) Thanks! Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 11, 2014 Share Posted July 11, 2014 Welcome to the Forum, Nagygabor679! Please check if the SOLIDEDIT command with Edge --> Color options is what you were looking for. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 11, 2014 Share Posted July 11, 2014 ...or Face and coLor Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 11, 2014 Share Posted July 11, 2014 ...or hold Ctrl+Pick, which isolates the the individual Face. This is also true for all sub-object elements, such as Face, Vertex, or Edge. Quote Link to comment Share on other sites More sharing options...
nagygabor679 Posted July 11, 2014 Author Share Posted July 11, 2014 Thanks for everybody! The Ctrl+Pick is the most simple solution. Quote Link to comment Share on other sites More sharing options...
nagygabor679 Posted July 11, 2014 Author Share Posted July 11, 2014 Oops! After that, the height/width/length properties missing from Properties window. How can I set the 3d solid height/width/length now? How can I see the set the 3d solid height/width/length now (by keyboard)? Quote Link to comment Share on other sites More sharing options...
nestly Posted July 12, 2014 Share Posted July 12, 2014 In AutoCAD, only 3D primitive objects have editable height/width/length/radius/etc properties. After manually applying property overrides to individual faces, the 3D solid is no longer a "primitive" object so you have to use Grips or the SOLIDEDIT tools to modify the object dimensions. Quote Link to comment Share on other sites More sharing options...
