Results 1 to 5 of 5
    Full Member WERDNA's Avatar
    Structural
    WERDNA's Discipline Details
    Structural Designer
    Structural
    AutoCAD 2015
    Feb 2012
    Scotland
    85
    Default Paste Special from Word
    Hi,
    I pasted some text from a word document into model space and have since deleted it. There seems to be some parts of the text still in the drg, there are some white blocks appearing when zoomed out that I cant pick, and they vanish when I zoom in, I have tried purging to no avail, is there a way of removing?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Any one of these three things should work.
    Make sure purge is set to delete zero length geometry and empty text items.
    WBlock the entire drawing.
    Turn on and thaw all layers. Select all (Ctrl+A). Deselect everything using a crossing window over the entire drawing, then delete what cannot be deselected.
    Drafting is a breeze.
    Senior Member Spaj's Avatar
    Spaj's Computer Details
    Win 7
    ASUS P5K
    Intel E8400
    4096Mb
    MSI Nvidia GTX660 2GB
    OCZ RevoDrive 128GB
    WD Black 1TB
    Samsung 27" LCD
    Civil
    Civil 3D 2016
    Oct 2013
    South Africa
    144
    Hi
    Also try turning on QTEXT. This makes it easy to spot spaces, blank lines etc.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    This from help:
    When QTEXT (Quick Text) is turned on, each text and attribute object is displayed as a bounding box around the text object. Turning QTEXT mode on reduces the time it takes to regenerate drawings that contain many text objects. Use the REGEN command to display the results of QTEXT on existing text.
  5. #5
    Structural
    Structural Designer
    Structural
    AutoCAD 2015
    Feb 2012
    Scotland
    85
    A belated response as I have been on holiday; that has indeed sorted the issue, thanks for the help.
  1. no paste special command
    By RobinEloquence in forum AutoCAD Beginners' Area
    Last Post: 10th Jul 2014, 12:01 pm
  2. Paste special
    By Z GUY in forum AutoCAD Beginners' Area
    Last Post: 17th Dec 2011, 04:33 am
  3. Can't Paste Special
    By ziemerd in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2010, 06:58 pm
  4. Paste Special Problem!!!! help?
    By tinkerbell in forum AutoCAD Drawing Management & Output
    Last Post: 1st Apr 2010, 09:59 am
  5. special paste
    By XAVIER in forum AutoCAD Beginners' Area
    Last Post: 19th Aug 2003, 08:09 pm
