hiandy Posted July 13, 2014 Share Posted July 13, 2014 Dear All, My name is Hiandy and I am using Autdesk Inventor Pro 2014 I have a problem with measurement unit. First, I created a part. Then, I used feature of 'thicken' to one surface. After that, I used feature 'make component' to make an assembly with 2 parts. Please see a file on attachment. My question: why the measurement units on part and assembly (mm) are different from the measurement unit on part (after assembly) which is inch? Please let me know, if you have questions. Would appreciate for your help. Thank you. Regards, HiandyUNIT DIFFERENT.pdf Quote Link to comment Share on other sites More sharing options...
phyro222 Posted July 16, 2014 Share Posted July 16, 2014 Are you using an assembly template in mm? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 16, 2014 Share Posted July 16, 2014 As indicated - when you Make Component you have to select the correct template. 1. It sounds like inch template is your Default - you can change the default. 2. You can always change the units of ANY file by going to Tools>Document Settings>Units Quote Link to comment Share on other sites More sharing options...
spiderdian Posted August 20, 2014 Share Posted August 20, 2014 I agree with JD. i encountered the same problem before and that is how you fix it. Quote Link to comment Share on other sites More sharing options...
