Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Senior Member
    numberOCD's Computer Details
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    Chicago/New York USA
    165
    Default Insert Blocks off of List with Attributes and Rotate the Blocks when inserted
    Good Morning,
    I am brand new to AutoLISP and am not picking it up quite as well.
    I'm trying to make a LISP that will insert around 1500 blocks at designated coordinates off a list I will make in Excel (or can transfer to a txt). The excel list will have X,Y coordinates, an angle of rotation, and 2 or 3 attributes.
    This LISP will not be for a long time use, it's mainly to get a large insertion completed for editing as construction comes along, so I only need to make it for functional purpose. If someone can guide me better in how to extract the information from the list into the LISP, that's the main thing I'm having trouble picking up.
    Thanks for any help!
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    Default Consider a script instead of LISP
    It might be easier to use a script to add blocks to an AutoCAD drawing if your data is coming from an Excel worksheet. For example, assume your Excel file looks something like the example below with your data in columns B through G.
    Enter the following in cell A2 using the Excel Concatenate function to create the command to add a block. It is important to use spaces as noted to force the command to go on to the next argument when it is executed. Note that there is one space before the 1 (for scale) and two spaces after it. Since an Enter cannot be included in this sequence we will uses @@@ as a place holder for it.
    Use fill down to create the insert commands for all the data.
    Copy Column A from row 2 to the last row (cell A4 in my example) to the clipboard.
    Open MS Word and paste as text.
    Use Replace and replace the text @@@ with ^p . This will place the second attribute value on a new line providing an Enter input to the command.
    Save the file as a .txt file.
    Change the file name extension to .scr . The filename should be something like: filename.scr
    In AutoCAD enter the Script command and select the .scr file. This should add multiple blocks at the specified location and angle.
    Senior Member
    not specified
    Apr 2014
    105
    You can use this routine to get information from text file. With A.txt is file and L is the result list. The item's type of L is String.
    Code:
    (setq L nil
          file (open "A.txt" "r"))
    (while (setq line (read-line file))
      (setq line (mapcar 'vl-princ-to-string (read (strcat "(" line ")")))
    	L (append L (list line)))
    (close file)
    Using Tapatalk
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    Irm maybe also rather than adding the Word step wrap the attribute in quotes "Apples" "Banannas". Pasting to Word need to make sure save as a TEXT file with .scr file extension, Word can add hidden characters.
    Nice clear explanation, well done.
  5. #5
    Windows 7 64-bit
    16 GB
    Education
    Education
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    BIGAL, The text string:
    -insert MyBlock 12.34,20.5 1 30 "Apples" "Bananas"
    will assign "Apples" "Bananas" to the first attribute of MyBlock. What syntax should be used to get an Enter key between the two values so that Apples is assigned to the first attribute and Bananas to the second attribute? My substitution of ^p added the Return key which did this. It would be cleaner to not have to do the substitution. Thank you.
  6. #6
    Senior Member
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    165
    Irm,
    This is the kind of method I've been looking for. I used to have a similar idea for drawing polylines with varying y coordinates and increasing x by one unit (5 feet) and I would paste that list into the command line. This remedy will definitely save me a huge deal of time for this task.
    Thanks a bunch!
  7. #7
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    Or maybe use autolisp syntax :
    Last edited by David Bethel; 15th Jul 2014 at 06:08 pm. Reason: Wrong Scale / Angle order
    R12 (Dos) - A2K
  8. #8
    Senior Member
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    165
    Irm,
    Do I need spaces around the ^p? I haven't gotten it to work quite yet, but it is coming along.
    David,
    How would I use your this sequence? I'm not quite familiar with autolisp yet. I copied down the sequence and ran it through Script. Is this the proper method? I got a prompt: "Point or option keyword required." followed by "Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]:"
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,548
    The simplest way would be to :
    Simply Copy Column "I" to the AutoCAD Command Line
    OR :
    • Copy column "I" into Notepad or any true ASCII editor
    • Save the new file to a known location ( c:\acad\insb.lsp] )
    • The file name and extension are not important in this scenario
    • At the AutoCAD command line type (load "c:/acad/insb.lsp")
    Notice the use of "/" vs the DOS standard for file locations. ( AutoLsip Requires this )
    Also the BLOCK / INSERT ATTRIBute quantities must be an exact match. In the same I posted MyBlock1 has (3) MyBlock2 has MyBlock3 has (2).
    There are work arounds for this but it didn't sound like that was a biggie for your use.
    R12 (Dos) - A2K
  10. #10
    Senior Member
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    165
    When I run the lsp named Test2.lsp it returns this test window
    This is the only line in the lsp right now
    (command "_.INSERT" "SIG" list( 12 36 0) 1 1 32 "781Z" "GYR")
    Any idea what's wrong?
    Thanks
  1. making a bom list from blocks with attributes
    By CADkitt in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Mar 2017, 08:21 am
  2. Rotate Dynamic Blocks on Insert with Option for Additional Rotate.
    By dortega4269 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2013, 08:23 pm
  3. Insert blocks and rotate to polyline
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Apr 2013, 06:30 pm
  4. LISP to insert blocks depending on certain attributes
    By cangelo3D in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Oct 2009, 08:50 am
  5. update or insert blocks with attributes
    By serdas in forum AutoCAD General
    Last Post: 6th Nov 2008, 08:46 pm
Tags for this Thread
