Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Senior Member
    numberOCD's Computer Details
    Windows 7
    HP EliteBook 8770w
    16Gb
    MEP 2014
    Apr 2010
    Chicago/New York USA
    165
    Ok,
    I took out the "List" with paranthesis and the Z coordinate and it is working by pasting the line in the command bar up until the Attribute Window. It still prompts me for the Attribute value, and that is one part I need to automate badly.
    It currently reads this
    (command "_.INSERT" "SIG2" "12,36" 1 1 32 "781Z" "GYR")
  2. #12
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    Leaving he Z axis value can lead to really weird results.
    Does the BLOCK have 2 or 3 Attributes?
    R12 (Dos) - A2K
  3. #13
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,548
    Quote Originally Posted by numberOCD View Post
    When I run the lsp named Test2.lsp it returns this test window
    Attachment 49920
    Thanks
    Well I guess there are file naming limitations after all
    It can only have 1 file extension ie .lsp not .lsp.shx
    Th extension cannot be .shx as the (load) command knows what a shx file is supposed to be
    R12 (Dos) - A2K
  4. #14
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    Hi numberOCD,
    To answer your follow up question to my original post.
    After selecting and copying column A to the clipboard and pasting it in to MS Word you will have something that looks like this (I have turned on the display of paragraph marks and spaces):
    Use Find and Replace as shown (no spaces) to replace @@@ with ^p. The results should look something like this where each attribute beyond the first is on a new line. Make sure there is only one paragraph mark at the end of the last line and no paragraph mark after it.
    When you go to save this file in Word use Save As and then choose the txt format. This will save the file in an ASCII format. Note, you can use Notepad to edit the .scr file but Notepad's Replace function does not include paragraph character (^p).
    AutoCAD expects script files to have the file extension .scr so chnage the file name using the file manager from:
    to:
    You can then use the script command to enter all the blocks.
    For a test of this process I created a simple block named MyBlock with two attributes. The names of the attributes is not important but the order is. Please let me know if you have any questions.
    ~ lrm
  5. #15
    Windows 7 64-bit
    16 GB
    Education
    Education
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    Here's a sample of the output of the MyBlockScript using a simple block with two attributes:
    ~lrm
  6. #16
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    This works not sure why yours doesn't.
    Code:
    (command "_.insert" "labelstn" "0,0,0" 1 1 0 "10" "20" "30" "40" "50")
  7. #17
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Can you upload a sample Excel file with a sample drawing that obtains the attributed blocks that you are going to use ?
    How many different attributed blocks to be inserted ?
  8. #18
    Windows 7 64-bit
    16 GB
    Education
    Education
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    Default Adding Blocks and Attributes with a Script from Excel
    Thanks BIGAL for the suggestion. I was trying to create a script that does not use AutoLISP but it is one way around the problem of including the Enter key. It simplifies the process by eliminating the need to do a replace in Word.
    Here then is the process for converting Excel data for the location and orientation of a bunch of blocks that each include several attributes.
    1. Layout your spreadsheet similar to the following, leaving column empty. I will be using column A for building the AutoCAD command for each block through the use of the Excel Concatenate function.
    2. Type into cell A2 the following expression paying careful attention to “ and spaces. Single quotes are used to start and end a string of text while double quotes “” are used to add a single quote. I have placed red dots where spaces should be included.
    3. Use Fill-down from cell A2 to create the other AutoCAD (actually AutoLISP) commands.
    4. Copy cells A2 to A4 (or however many rows you have) to the clipboard with Ctrl-C.
    5. Open Notepad and Paste the commands into it. The file should look something like the following.
    6. Save the file in Notepad so that is has a file name extension of .scr.
    7. In an AutoCAD file that includes the definition of the blocks used give the Script command and select the .scr file.
    Here is the result.
    8. Enjoy!
    I have included the Excel, .scr, and AutoCAD file as an example.
    ~lrm
  9. #19
    Senior Member
    not specified
    Apr 2014
    105
    Suppose that you have a txt file like this , call it "D:/A.txt" :
    MyBlock 12.34 20.5 15 Apples Bananas
    MyBlock 14.12 22.5 30 Cherries Donuts
    MyBlock 16.11 24.5 45 Eggs Figs
    You can use this lisp function to insert your block:
    Code:
    (defun c:test()
      (setq L nil
    	file (open "D:/A.txt" "r"))
      (while (setq line (read-line file))
        (setq line (mapcar 'vl-princ-to-string (read (strcat "(" line ")")))
    	  L (append L (list line)))
      (close file)
      (foreach line L
        (command "-insert" (car line)
    	     (list (atof (nth 1 line)) (atof (nth 2 line)))
    	     1 1 (atof (nth 3 line))
    	     (nth 4 line) (nth 5 line)))
    Using Tapatalk
  1. making a bom list from blocks with attributes
    By CADkitt in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Mar 2017, 08:21 am
  2. Rotate Dynamic Blocks on Insert with Option for Additional Rotate.
    By dortega4269 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2013, 08:23 pm
  3. Insert blocks and rotate to polyline
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Apr 2013, 06:30 pm
  4. LISP to insert blocks depending on certain attributes
    By cangelo3D in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Oct 2009, 08:50 am
  5. update or insert blocks with attributes
    By serdas in forum AutoCAD General
    Last Post: 6th Nov 2008, 08:46 pm
Tags for this Thread
