Results 1 to 10 of 10
    Forum Newbie
    HVAC
    MorgaineDax's Discipline Details
    CAD Technician
    HVAC
    Building design and coordination for a mechanical contractor.
    AutoCAD 2015
    May 2011
    Nova Scotia
    9
    Cool UCS and Modelspace Viewport Problems
    So we do a lot of 3D coordination using AutoCAD and Fabrication, and since we upgraded to 2015, we've been having a lot of issues with viewports and the UCS.
    We all typically have at 3 viewports in modelspace. One big one for the plan view, one front view, and a side view. We change them a lot on the fly depending on what we need to see. For example, we'll place a line of ductwork in the plan view and then switch over to one of the side or front views to check clearances between services and adjust accordingly.
    However, now the viewports keep changing their UCS and we don't know how to fix it. So we'll set a view port to plan view, go to the front view, and not be able to move or dimension anything properly because the UCS looks like it's matching the plan view? Instead of having Y pointing "up" and x pointing "right" in every viewport, the UCS in every viewport will relate to the last view you set.
    We're assuming it's some variable that didn't get carried over in the upgrade, but no one can figure out how to get it back to the way we usually draft.
    Don't know if this is the proper forum, but please help?
    AutoCAD 2013
    Nov 2011
    5,964
    Check out this snippet from the SYSVDLG regarding UCSVP, might be the variable you are after.
    NOTE that it is VIEWPORT SPECIFIC. I hope that helps you.
    Or might you just want to set your UCSFOLLOW variable to 1?
    It is always a good idea to keep a current .SVF (System Variable File) for safe keeping.
    To create one, at the bottom of the SYSVDLG box, choose SAVE ALL, as insurance against just
    such an inevitability, a system crash or other CADastrophy.
    In that way it is very easy to load, or restore your personal preferences on any machine.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,370
    Could it be that the Dynamic UCS feature is enabled?
    Senior Member Spaj's Avatar
    Spaj's Computer Details
    Win 7
    ASUS P5K
    Intel E8400
    4096Mb
    MSI Nvidia GTX660 2GB
    OCZ RevoDrive 128GB
    WD Black 1TB
    Samsung 27" LCD
    Civil
    Civil 3D 2016
    Oct 2013
    South Africa
    144
    Maybe try UCSFOLLOW 1 > UCS W > UCSFOLLOW 0
  5. #5
    Forum Newbie
    HVAC
    CAD Technician
    HVAC
    AutoCAD 2015
    May 2011
    Nova Scotia
    9
    Quote Originally Posted by Dadgad View Post
    I think this fixed it on my workstation; I'll see if it works for everyone else in the office. Thanks!
  6. #6
    Forum Newbie
    HVAC
    CAD Technician
    HVAC
    AutoCAD 2015
    May 2011
    Nova Scotia
    9
    Quote Originally Posted by MorgaineDax View Post
    Nope, that fixes it somewhat, but there's another bug that keeps popping up now. You'll be working fine in multiple viewports for a while, but eventually the other UCSs in the other VPs will grey themselves out and when you switch over to work in a different viewport, you won't be able to annotate and move objects properly.
    You can use the view controls in the locked VP to get the UCS unlocked, but then it locks the other ones. So I'll work in top view for a while and it'll be fine. But then I move to a front view and I'll only be able to move or draw side to side, but not up or down.
  7. #7
    AutoCAD 2013
    Nov 2011
    5,964
    Sorry to hear that didn't fix it for you. Did you remember to enter an appropriate value, in each of the viewports, as opposed to just once,
    assuming that the setting would be global?
  8. #8
    Forum Newbie
    HVAC
    CAD Technician
    HVAC
    AutoCAD 2015
    May 2011
    Nova Scotia
    9
    I definitely remembered that! Which did fix the issues for the UCS flipping around and changing to Z,X or Z,Y in relation to the first VP. I'm just not sure if this "greyed out" new problem is related or a separate bug or variable problem.
  9. #9
    AutoCAD 2013
    Nov 2011
    5,964
    Might there be another computer available, which is operating as you would like it to, upon which you could
    save an .svf (system variable file), so that you can apply those settings to one of the computers
    which is misbehaving, as a test?
  10. #10
    Full Member
    AutoCAD LT 2011
    Nov 2012
    Ireland
    72
    I had a similar problem before and as far as I remember 'UCSORTHO' set to '1' fixed it.
  1. Linked viewport modelspace
    By OMEGA-ThundeR in forum AutoCAD Drawing Management & Output
    Last Post: 21st Mar 2014, 02:43 pm
  2. Modelspace Dimensions in Viewport
    By SLW210 in forum AutoCAD General
    Last Post: 19th Mar 2012, 08:00 pm
  3. Visible in Viewport, not in modelspace
    By Kremer in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2011, 10:56 pm
  4. VBA Viewport to ModelSpace coordinates..
    By hardwired in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2008, 04:47 pm
  5. Viewport <> ModelSpace Relation (VBA)
    By iTijn in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Oct 2007, 05:35 am
Tags for this Thread
