Paper Space View Port Scale Control
Tappet
Hi All,
I am a newbie to this site.
An issue with view port scaling has occurred, & I cannot find a solution anywhere, so I'm wondering if you can help.
I use LT 2011, and have set new layers in a dwt file I intend to split into various disciplines for use later.
The problem I have is to do with the view port scale control, in PS. The template was originally set in metric, to view the paper space @ 1:1. But somewhere along the way, this was altered to 1:30. (Not certain where or when).
Trouble is, I cannot change this value back to 1:1 - no matter what I do.
Been through and cleared out the scale list of extraneous listings; have tried to set the scale from both the list & manual entries; have changed the view port scale (ms set) to 1:100 & then tried again, all to no avail.
I would love to change the template to a new one, but I have just shy of 500 layers set, and use layer filters extensively - and I am unable to export the filters to another template - so I'm committed to working this little dilemma out.
I've attached an image of the scale control (just to be sure I have described the problem clearly).
If anyone can offer me another option, or a fix, I will be great full.
Thanks,
Tappet. http://www.cadtutor.net/forum/images/smilies/confused.png
Is the viewport in question locked or on a locked layer?
enter / activate or select the viewport and try adjusting this value?
Thanks for the reply.
No layers are locked.
There are no view ports in the layouts - I've deleted these to ensure that only the paper space is available.
I am trying to set the paper space ratio scale to 1;1 - It currently is 1:30. I assume (maybe incorrectly) that this will create scaling issues with blocks brought into the dwg in the paper space Eg a title block. I will try this shortly. I also observed this issue on a layout at work - the paper space scale was "scaled to fit." Could this have something to do with the dwg limits?
If the layout sheet is always drawn @ 1:1 in paper, why would there be a need to have access to the scale box in paper space? Should it not be 'grayed' out?
Hi Rob Draw,
Sorry, but my 2011 version doesn't have a save feature, as shown above.
Can I build a button in the customisation dialog box?
Slightly confused about your scale query.
Paper space is always 1:1 that I'd by its nature correct. Its representative of paper. Of what will be printed A1 size or A0 etc
You have to have a viewport to access the viewport scale feature. Which is your portal to model space. This is set to scale down model space onto your paper.
Create a viewport. Click, set the scale accordingly. Check your measurements and that should be it!
