Results 1 to 6 of 6
    Forum Newbie
    AutoCAD LT 2015
    Jul 2014
    8
    Default Determine what a viewport's custom scale is
    Hi all,
    Does anyone know of a way to determine what the custom scale of a viewport is?
    I have some existing drawings that are using non-standard scales and simply state 'Custom' in their properties window.
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    867
    i know a workaround.....
    make a line in paperspace over your viewport. make it say 100mm long. copy it so you have 2.
    use CHSPACE command to push it through your viewport without changing its appearance. AutoCAD will have scaled it to make this work.
    measure the line you now have in model space. divide that length by the eg. 100mm you started with.
    the difference in size is the scale factor. so if the new line is 5000mm, your viewport scale is 1:50
    hope this helps!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    In Properties, below Standard scale field there is Custom scale were you have a number; that is the scale ratio which you can use to calculate the report.
    For metric, divide 1 with that ratio; example:
    ratio = 0.5 --> 1 / 0.5 = 2 --> 1:2 scale
    For imperial, multiply 12 with said ratio; example:
    ratio = 0.5 --> 12 * 0.5 = 6 --> 6":1'-0" scale
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    AutoCAD 2013
    Nov 2011
    6,051
    Welcome to CADTutor.
    After custom scale, I suspect there will be a number, which represents the scale.
    If you look at the image you will see my quick properties palette reporting that
    the custom scale is .025, meaning 25/1000s, or 1/40th. Viewport scale equals 40.
    I have never used LT, but I imagine your display is not terribly different.
    You can also check in PROPERTIES, instead of in Quick Properties.
    Mircea and Stuart to the rescue, good job guys!
  5. #5
    Forum Newbie
    AutoCAD LT 2015
    Jul 2014
    8
    Amazing, thank you all so much!
    I really like that workaround designerstuart, creative
    And thanks for the welcome to the forums Dadgad.
  6. #6
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by designerstuart View Post
    hope this helps!
    I didn't notice this earlier, but that is another interesting way to go, and if you are watching your commandline, after you use the changespace command,
    the commandline will report the scaling which took place. Or you can just hit F2,
    and check in your commandline history to see the scaling report.
  1. how to determine the scale of the drawing?
    By djole in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th May 2017, 01:31 pm
  2. Layout tab's viewport scale box won't show standard scale menu.
    By macsee in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2014, 01:36 pm
  3. Model Scale vs. Viewport Scale vs. Plot Scale?
    By Sbeth85 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Jan 2014, 04:32 pm
  4. Extracting the "Custom scale" value from an existing viewport
    By landsurveying in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2011, 10:45 am
  5. Custom Viewport Scale
    By CADken in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jun 2007, 12:33 pm
Tags for this Thread
