Results 1 to 5 of 5
    Full Member
    AutoCAD 2014
    Jul 2014
    57
    Default ;error: Unknown function definition when it is clearly in my lisp.
    Help, I keep getting this stupid error no function definition even though I have clearly defun it in my lisp.
    Code:
    (defun ISOCP3TEXT ()
       (command "-style" "isocp3" "isocp.shx" "3" "1" "0" "no" "no")
    (defun ISO3 ()
       (ISOCP3TEXT)
       (setvar "clayer" "0")
       (setq pt1 (getpoint ""))
       (initdia) (command ".mtext" pt1)
    (defun c:meh ()
       (ISO3)
    If you are wondering, I am using meh which may seem redundant but in my main source code, I actually need to call up iso3 due to a dialog box settings thing. For some reason, when I try to run meh, I keep getting ; error: no function definition: ISO3 when clearly I do have a defined function ISO3. Help please.
    Senior Member
    not specified
    Apr 2014
    105
    Change iso3 like this and try again:
    Code:
    (defun ISO3 ()
       (ISOCP3TEXT)
       (initdia) (command ".mtext" (getpoint ""))
    Using Tapatalk
    Full Member
    AutoCAD 2014
    Jul 2014
    57
    Same error. Don't worry now, all fixed
    Forum Newbie
    heschr's Computer Details
    Windows 7
    AutoCAD 2014
    Jan 2014
    8
    Quote Originally Posted by Lee Chu Chu View Post
    (defun c:meh ()
    (ISO3)
    Is there a closing bracket missing?
  5. #5
    Full Member
    AutoCAD 2014
    Jul 2014
    57
    In the code that I have posted here, yes but not in my lisp. I found out that I made the silly mistake of spelling iso with a zero instead of an "o".
  1. after loding lisp : "error no function definition , ACET-STR-FORMAT"
    By Salama in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2014, 11:03 pm
  2. NET lisp error: no function definition
    By LINHOREKA in forum .NET, ObjectARX & VBA
    Last Post: 5th Sep 2013, 06:06 pm
  3. error on lisp (no function definition: SF)
    By sachindkini in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2012, 11:16 am
  4. error: no function definition
    By its.personal in forum AutoCAD General
    Last Post: 9th Jun 2009, 11:02 am
  5. error no function definition: DTR for AutoCAD 7
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2007, 02:27 pm
Tags for this Thread
