Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    Architecture 2015
    Jul 2014
    65
    Cool Is there a way to set a tolerance for trimming lines so minuscule gaps trim?
    The lines are so close that I cannot even see a gap but apparently there is a minuscule gap therefore the lines aren't trimming. Rather than extend all of them, is there a way to adjust the tolerance so they trim anyway? this could save a lot of time.
    Thanks,
    K
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    This is probably a matter of not picking your points correctly. Use object snap when drawing. Using a zero radius fillet with trim mode on can fix errant picks by filling those gaps.
    Drafting is a breeze.
    Full Member Ender181's Avatar
    Ender181's Computer Details
    how many pixels can you count? I get less than that
    my flash drive
    I wish
    HP f1905e
    Civil
    Ender181's Discipline Details
    Student
    Civil
    Civil 3D 2009
    Jun 2014
    Pacific NorthWest
    27
    That is really annoying when that happens, and while it would be nice if there is a tolerance that you can set, a runner up in efficiency is using the shift key while trimming to extend a line instead and then you can release the shift key and go back to trimming.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    If there is a gap then it sounds like you need to extend rather than trim. Maybe you can clarify what it is you are trying to do.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Assuming "gaps" are the problem, you can set EDGEMODE to 1 and still TRIM the object(s) even with "gaps", but if there are indeed "gaps" there's really no fix other than verifying what's not correct (the endpoint, or the intersecting geometry) and correcting accordingly. FILLETing will close a corner, but it doesn't necessarily put the corner in the correct place if the geometry is not precisely located to begin with.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by nestly View Post
    .... FILLETing will close a corner....
    ...and to do that - set Fillet Radius = 0.
    It will trim and extend as needed.
    Attach an example file here that you are having difficulty with (you should not be experiencing this difficulty) for other tips, tricks and suggestions.
  7. #7
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by JD Mather View Post
    I guess it wasn't clear enough when I said:
    Quote Originally Posted by RobDraw View Post
    Using a zero radius fillet with trim mode on can fix ... those gaps.
  8. #8
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    ... Or just use a zero radius fillet.
  9. #9
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GTX 650 (H)
    520 gb SSD 0/ 1TB 1 (W) 256 GB SSD (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2019
    Sep 2002
    Winston-Salem, NC - USA
    5,678
    Maybe something else is going on here? In all my years of AutoCAD I have never had gaps when closing corners (fillets). I'd like to watch the OPs work flow and see what is going on. I sense some type of bad drawing habit perhaps.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  10. #10
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by f700es View Post
    So you probably agree with this:
  1. Command that checks if all lines are together and no misstakes/gaps
    By vilhelm65 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2014, 06:54 pm
  2. trimming many lines in auto cad 2013
    By PRA3889 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2014, 04:46 am
  3. Gaps between text/lines and colours
    By koog in forum AutoCAD General
    Last Post: 12th Jul 2013, 11:46 am
  4. Trimming Lines within a rectangle
    By Sundar in forum .NET, ObjectARX & VBA
    Last Post: 20th Jan 2012, 05:19 am
  5. Blocks trimming lines on insertion
    By Ivan006 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th May 2010, 08:10 pm
Tags for this Thread
