Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Full Member
    Architecture 2015
    Jul 2014
    65
    Laughing
    Quote Originally Posted by nestly View Post
    Assuming "gaps" are the problem, you can set EDGEMODE to 1 and still TRIM the object(s) even with "gaps", but if there are indeed "gaps" there's really no fix other than verifying what's not correct (the endpoint, or the intersecting geometry) and correcting accordingly. FILLETing will close a corner, but it doesn't necessarily put the corner in the correct place if the geometry is not precisely located to begin with.
    THANK YOU. This is exactly it.
  2. #12
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    You've got answers on how to "fix" the gaps but have you figured out what is causing them in the first place?
    Depending on what you are drawing, there may be other issues that are not being addressed.
    Drafting is a breeze.
  3. #13
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GTX 650 (H)
    520 gb SSD 0/ 1TB 1 (W) 256 GB SSD (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2019
    Sep 2002
    Winston-Salem, NC - USA
    5,678
    Yeah Rob, something is up for sure.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  4. #14
    Full Member
    Architecture 2015
    Jul 2014
    65
    Quote Originally Posted by RobDraw View Post
    I appreciate you wanting to dig deeper but in this instance, I am only concerned as to how to fix them. What is causing them is irrelevant to me for I did not create the drawing. My own drawings are gap free and i don't a lesson on how to fillet and snap but appreciate the enthusiasm. Thank you.
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I wish I knew that from the start. My responses were hedged a bit because I though the gaps were a result of your drafting and did not want to insult you.
  6. #16
    Full Member
    Architecture 2015
    Jul 2014
    65
    no worries!
  1. Command that checks if all lines are together and no misstakes/gaps
    By vilhelm65 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2014, 06:54 pm
  2. trimming many lines in auto cad 2013
    By PRA3889 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2014, 04:46 am
  3. Gaps between text/lines and colours
    By koog in forum AutoCAD General
    Last Post: 12th Jul 2013, 11:46 am
  4. Trimming Lines within a rectangle
    By Sundar in forum .NET, ObjectARX & VBA
    Last Post: 20th Jan 2012, 05:19 am
  5. Blocks trimming lines on insertion
    By Ivan006 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th May 2010, 08:10 pm
Tags for this Thread
