Results 1 to 5 of 5
    Full Member MinaRAI's Avatar
    AutoCAD 2013
    Jul 2014
    26
    Default Tan Tan Radius question
    Hi,
    I'd like to draw the image below in 2D but I hit a problem with the bottom part in relation to the side radius of 3.5mm.
    Drawn the circle with a radius of .75 so I can use the "Circle>Tan Tan Radius" command to make the radius 4.25mm. Trimmed the excess edges and used PEDIT so I can apply offset .75mm outwards. The offset polyline showed some error that did not gel well with the bottom portioon. (the error is encircled in red). Edges would not meet as in the drawing exercise.
    Now redone it using the Tan Tan Radius based on the bigger diameter but the result is the same as that of the .75 offset polyline result.
    Now if I tried to drag the endpoints to meet the end of the 1.5mm x 4mm base but the radius will change. It says there that the radius will change to 4.008mm. Drawing exercise says it should be radius of 3.5mm.
    Same with the bottom portion. If I drag the bottom part to meet the excess of the circle/arc created via the tan tan radius, 1.5mm x the 4mm dim will be affected. See image attached.
    The other dims are correct but this radiius of 3.5mm is not. There could be something wrong with the way I did the circle with the Tan Tan Radius....
    How will you do the drawing if it were you....?
    Can you teach a self-studier some tips and tricks please...
    Thank you!
    Senior Member
    hoss's Computer Details
    Windows 7 - 64 Bit
    Dell Precision T1600
    MEP 2012
    Jun 2007
    South Yorkshire, UK
    236
    Can you attach an image or the drawing
    its hard to follow what you are trying to do without a picture
    AutoCAD 2012 & AutoCAD MEP 2011
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    In my opinion the dimensions are all correct. It is your approach that is in error. Draw the perimeter first then offset to the inside. Trim as required. Like this...
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by MinaRAI View Post
    Drawn the circle with a radius of .75 ....
    This dimension is not on your drawing...
    Work from the outside towards the inside as ReMark suggested.
    1. You know that the center of the arc is somewhere in space 3.5 from the endpoint of the 1.5 vertical line.
    2. You know that the center of the arc is somewhere in space 5 (1.5+3.5) from the center of the smaller circle.
    There are only two points in space that satisfy both of those conditions.
    One of the two possible solutions does not make logical sense.
    You have found the unique solution. (the construction lines in the image below are not needed - I included them only for illustration)
  5. #5
    AutoCAD 2013
    Jul 2014
    26
    Oh wow! Thank you for the set of instructions there. I really went from slow to very slow understanding or trying to remember drafting 101...I had the chance to do it in a different version. Please see below.
    Someone mentioned also that this can be done via a point_tan_radius..
    Can you guys help me understand that too...
    I really appreciate the guide drawings. Thanks very much for that. Please bear with me as I am currently having trouble with where to go for self-study at the moment as the previous location I did went is having problems. Had to do the drawing based on the illustrations and a couple help from other concerned gurus on a different version(2013). And it took me hours for just this one...(no kidding on it. I think I went blank trying to grasp the newer version from 2010 from which I also am trying to use. Had just started late June till now intermittently.)
  1. radius
    By garylu in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 9th Feb 2014, 04:00 am
  2. Radius & Translation Question
    By svrkjg in forum AutoCAD General
    Last Post: 10th Dec 2012, 08:40 am
  3. Basic question: How to edit the location and radius of a hole in a block?
    By zmarcoz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Jul 2012, 10:32 am
  4. Stretch a circle with grips and specify the radius or change in radius
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 5th Aug 2010, 09:31 am
  5. Arc with Radius
    By unforgiven_576 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Nov 2008, 10:33 pm
