Results 1 to 8 of 8
    Full Member
    AutoCAD 2013
    Jul 2014
    india
    33
    Default Filter all block attribute texts except one particular text
    Hi All,
    I am confused with filters, I am working on P&ID which is been copied from other drawing. Here I have number of blocks with attribute texts.....where I have to change all dias of all blocks except which has 3/4" dia text. Is it possible to select all block attribute texts at a time except which have 3/4" dia text.
    Full Member
    jarr3tt88's Computer Details
    8GB
    NVIDIA Quadro K600
    Architectural
    jarr3tt88's Discipline Details
    Draftsman
    Architectural
    New high end residential, townhouses, and commercial buildings
    AutoCAD LT 2014
    Nov 2013
    Long Island
    86
    Turn off the layer 3/4" dia. text, and use the select similar command.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    More than likely, the 3/4" dia text is not on it's own layer.
    As to the OP, if there aren't too many variations, you could use Edit/Find for all the values other than 3/4" dia.
    Drafting is a breeze.
    Full Member
    AutoCAD 2013
    Jul 2014
    india
    33
    Thank you Jarr and Rob for your Suggestions. Rob I agree with your comment that I can find/edit for 3/4" text, but here is not problem with 3/4" text my problem is to select all block attribute texts except 3/4" text containing blocks and I need to blank (delete) all block attribute texts. I need work on number of drawings of these kinds............in various drawing I need except only particular text remaining all to be deleted. I want to perform this action in various drawing so I cannot find and edit each block text.
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You can to do it with GATTE but it still requires some work. GATTE changes all or some of a chosen block to be blank. When prompted to change all select "No". You can then use a window select to pick all of them and then shift deselect the ones with 3/4". If you have a lot with 3/4" it could be tedious but it is less work than the current alternative.
  6. #6
    Full Member
    8GB
    NVIDIA Quadro K600
    Architectural
    Draftsman
    Architectural
    AutoCAD LT 2014
    Nov 2013
    Long Island
    86
    I was going to suggest what rob said, selecting all text then deselecting the 3/4" Is this a height of the text? Or wording 3/4"?? I'm going to search the select similar, I remember it having text height as an option. Or maybe that was for match properties. Personally I'm a fan of the annotative text. If that was annotative you could just change the scale and only the 3/4" text would be visible.
    ANNOALLVISIBLE = 0 only shows the current scale annotative objects
  7. #7
    Full Member
    AutoCAD 2013
    Jul 2014
    india
    33
    Thank you Rob and Jarr.................Rob suggestion is comparatively similar with my problem, but this is also selects particular block at time not selects all blocks at at a time. I tried GATTE it is also similar the way I am working, I always select block reference from quick select when all the particular blocks were selected I will deselect texts which were not required to change and I will edit remaining from properties manager. Once again thanks..I think some body has write lisp for this issue.....
  8. #8
    AutoCAD 2013
    Nov 2011
    5,994
    How about using the FILTER command?
  1. Change Text (Not Attribute Text) in Block
    By dinhvantrang in forum .NET, ObjectARX & VBA
    Last Post: 22nd Jan 2014, 06:48 am
  2. Convert block+text -----> block + attribute
    By bono05 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Sep 2013, 02:27 pm
  3. filter value attribute inside a block
    By svorgodne in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2010, 02:44 am
  4. (dynamic)Blocks, attribute texts and visibilities
    By OMEGA-ThundeR in forum AutoCAD General
    Last Post: 12th Dec 2008, 11:39 pm
  5. Creating a Block w/ Text Attribute
    By CADken in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jul 2007, 07:27 pm
