Results 1 to 10 of 10
Thread: SHX fonts
    Forum Newbie
    not specified
    Jun 2006
    7
    Default SHX fonts
    Anyone know of a good website to find SHX fonts? I have been trying to figure this out for about a week now on and off. I want a simple stencil font for autocad that is NOT TTF. My company is purchasing a laser engraver to cut stencil letters (small -- .06" to .12" character height). The diameter of the laser is around 0.0015" If the laser vectors a TTF, the space between the "meat" of the letters holding it together will be too great.
    I am really wanting to be able to create my OWN .SHX font file. Anyone have a lisp or know how to do this? I know it can be done.
    Brian
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    go here ---> http://www.cadresource.com/library/fonts.html
    scroll down about 3/4ths of the way down, download the STENCIL.zip file. import the SHX file into your support filepath directory, and you're good to go. i just tried it and it works.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    not specified
    Jun 2006
    7
    I downloaded the zip file, extracted the files and put them in the Font Directory of AutoCAD. I also put them in the Windows FONT directory. When I open up autocad, I can't see them when I do multi line text. U got any idea what I'm doing wrong?
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    i used single line text. try that 1st....
  5. #5
    Forum Newbie
    not specified
    Jun 2006
    7
    I finally did get the Stencil shx text to work. I was about to go into the Format menu and chang the Text Style and pull it up. From there I could use single line text and it worked. Unfortunately the bubble letters will not work for me. I feel like I am going to have to create my own text. The guy that I know that did this composed his text around 3 years ago. The company still uses it to this day. He said he used a lisp command and did it that way and it saved the file as a shx. I've been looking for the lisp command, but no luck.
    On another note... I have 2002 autoCAD full version on my work PC. I can not use the command txtexp. Anyone know why?
    Brian
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    Quote Originally Posted by BrianSouders
    because that's an Express Tools command, i don't think ET comes with v2002. only v2004+.
    just search some LISP archives on the net somewhere, you'll find it. or i think there's an ET add-on for your version... not sure tho, someone else help! haha.
    EDIT: also, i'm curious, what about the font don't you like? that seemed to be exactly what you were looking for, it looks just like Arial (or close enough). ????
  7. #7
    Forum Newbie
    AutoCAD LT 2009
    Nov 2008
    2
    Quote Originally Posted by StykFacE View Post
    go here ---> link removed due to low post count (see above)
    I am looking for the same thing (a repository of .shx files) and it appears this website no longer exists.
    Any suggestions?
    Thanks,
    Rob
  8. #8
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    Check out this website:
    http://cg.scs.carleton.ca/~luc/autocad.html
    P.S. A Stone Temple Pilots Fan?
    "Those Who Pay Attention Will Be Rewarded"
  9. #9
    Forum Newbie
    AutoCAD LT 2009
    Nov 2008
    2
    BOB'27T:
    Thanks for the link, unfortunately quite a few of the fonts sites don't seem to be active anymore.
    Btw, my username is a reference to The Tick cartoon. Nothing against STP though!
    EDIT: I did find this site (www.cadcorner.ca/textstyles.php), but it doesn't have the 5 font types I am looking for!
  10. #10
    TariqRaheel
    thanks.........
