BrianSouders Posted August 28, 2006 Share Posted August 28, 2006 Anyone know of a good website to find SHX fonts? I have been trying to figure this out for about a week now on and off. I want a simple stencil font for autocad that is NOT TTF. My company is purchasing a laser engraver to cut stencil letters (small -- .06" to .12" character height). The diameter of the laser is around 0.0015" If the laser vectors a TTF, the space between the "meat" of the letters holding it together will be too great. I am really wanting to be able to create my OWN .SHX font file. Anyone have a lisp or know how to do this? I know it can be done. Brian Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 28, 2006 Share Posted August 28, 2006 go here ---> http://www.cadresource.com/library/fonts.html scroll down about 3/4ths of the way down, download the STENCIL.zip file. import the SHX file into your support filepath directory, and you're good to go. i just tried it and it works. Quote Link to comment Share on other sites More sharing options...
BrianSouders Posted August 28, 2006 Author Share Posted August 28, 2006 I downloaded the zip file, extracted the files and put them in the Font Directory of AutoCAD. I also put them in the Windows FONT directory. When I open up autocad, I can't see them when I do multi line text. U got any idea what I'm doing wrong? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 28, 2006 Share Posted August 28, 2006 i used single line text. try that 1st.... Quote Link to comment Share on other sites More sharing options...
BrianSouders Posted August 29, 2006 Author Share Posted August 29, 2006 I finally did get the Stencil shx text to work. I was about to go into the Format menu and chang the Text Style and pull it up. From there I could use single line text and it worked. Unfortunately the bubble letters will not work for me. I feel like I am going to have to create my own text. The guy that I know that did this composed his text around 3 years ago. The company still uses it to this day. He said he used a lisp command and did it that way and it saved the file as a shx. I've been looking for the lisp command, but no luck. On another note... I have 2002 autoCAD full version on my work PC. I can not use the command txtexp. Anyone know why? Brian Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 29, 2006 Share Posted August 29, 2006 On another note... I have 2002 autoCAD full version on my work PC. I can not use the command txtexp. Anyone know why? because that's an Express Tools command, i don't think ET comes with v2002. only v2004+. just search some LISP archives on the net somewhere, you'll find it. or i think there's an ET add-on for your version... not sure tho, someone else help! haha. EDIT: also, i'm curious, what about the font don't you like? that seemed to be exactly what you were looking for, it looks just like Arial (or close enough). ???? Quote Link to comment Share on other sites More sharing options...
BiPolarBear Posted November 18, 2008 Share Posted November 18, 2008 go here ---> link removed due to low post count (see above) scroll down about 3/4ths of the way down, download the STENCIL.zip file. import the SHX file into your support filepath directory, and you're good to go. i just tried it and it works. I am looking for the same thing (a repository of .shx files) and it appears this website no longer exists. Any suggestions? Thanks, Rob Quote Link to comment Share on other sites More sharing options...
BOB'27T Posted November 18, 2008 Share Posted November 18, 2008 Check out this website: http://cg.scs.carleton.ca/~luc/autocad.html P.S. A Stone Temple Pilots Fan? Quote Link to comment Share on other sites More sharing options...
BiPolarBear Posted November 18, 2008 Share Posted November 18, 2008 BOB'27T: Thanks for the link, unfortunately quite a few of the fonts sites don't seem to be active anymore. Btw, my username is a reference to The Tick cartoon. Nothing against STP though! EDIT: I did find this site (www.cadcorner.ca/textstyles.php), but it doesn't have the 5 font types I am looking for! Quote Link to comment Share on other sites More sharing options...
Guest TariqRaheel Posted April 17, 2010 Share Posted April 17, 2010 thanks......... Quote Link to comment Share on other sites More sharing options...
