jarr3tt88 Posted July 23, 2014 Share Posted July 23, 2014 I'm having another issue with dynamic blocks and attributes. I'm having an issue now with dynamic blocks that are created and need to be edited, they have attributes. When I created the block and I mirror them, fine they are awesome. Apparently now some setting or something got screwed up. I tried searching for an answer and found nothing. When I edit the block, and save and close it, the blocks that are mirrored now have the text mirrored! This didn't happen before, so its very frustrating. The reason I didn't create the blocks to have flips is because it was faster to just mirror the blocks as needed and rotate (flips I needed two separate blocks vert. and horz.) Why is every dynamic block with attributes now acting like mirrtext is 1. It might be automatically ATTSYNC itself, if thats the case, I don't want it to. Please help, thank you in advance. Quote Link to comment Share on other sites More sharing options...
hoss Posted July 24, 2014 Share Posted July 24, 2014 Possible to attach the file so we can have a look I tried to replicate this, but not having the issue you are experiencing Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted July 24, 2014 Author Share Posted July 24, 2014 Of course Hoss Broken Dynamics Mirrored.dwg I just tried to make another dynamic block with attributes in the same file and a brand new file. Both places had the same effect. Maybe I just didn't notice this before and it always did it. It doesn't seem right to make one change and all the attributes go upside and backwards if mirrored. If there is no system variable I can change to stop this from happening, I guess I'm just going to have to make flips from now on OR Just not make changes to blocks defined in a drawings already :/ I was a fan of attributes because you could just mirror the block, and regular text doesn't mirror correctly in a block, makes no sense! Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted July 25, 2014 Author Share Posted July 25, 2014 Anyone have any ideas? Now If I just change one thing about a block, all the text is wong, or the block resets....I don't understand what happened or why. I used to be able to make plenty of changes, but if it has attributes, and is dynamics, any changes to anything all hell breaks loose, and I have to fix every block. I think I found a workout around for next time, but this shouldn't be an issue when editing. Even if I don't touch the attributes or attsync it still flips and upside down. I will use text that have match to layout orientation from now on. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted July 26, 2014 Share Posted July 26, 2014 From the help file: MIRRTEXT affects text that is created with the TEXT, ATTDEF, or MTEXT commands; attribute definitions; and variable attributes. Text and constant attributes that are part of an inserted block are reversed when the block is mirrored regardless of the value of MIRRTEXT. EDIT: Adding a flip parameter did not cause the text to reverse direction. If you could post a "before and after" example, I'll help you build the block the way it needs to be to get it the way you want. Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted July 28, 2014 Author Share Posted July 28, 2014 My mirrtext is always 0, and will always be zero. The blocks I'm creating are fine....the issue comes when I need to make edits to them. I just started at this office and learning about dynamic blocks. I'm trying to create "smart blocks" So even if I create a block and start using it, there are edits that I might want to make to them. Its just really confusing that once the block is complete and mirrored its fine, exactly like I want it. But once I make a single change and save it, then the attribute flips backwards if it was mirrored. I probably just didn't notice this before, I don't think text should mirror itself even if I don't touch the attributes. Regular blocks with attributes work fine, mirrored and edited. Dynamic blocks with attributes, mirrored become backwards. Like I said, I guess if no one else has seen this before, I will just add a text type of 0 rotation (already started this) and a flip if a block might need text at 90 degrees. Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted November 6, 2014 Author Share Posted November 6, 2014 I still never found an answer to this problem. Has anyone else seen this issue? Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
