Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie DRAFTOLOGIST's Avatar
    Map 3D 2014
    Jul 2014
    6
    AutoCAD Edit Reference in Place - Colour change issue
    Has anyone experience this or know why this happens?
    dwg A is x-refed to dwg B.
    am working on dwg B & click on x-ref and go into Edit reference in place.
    if I now click on
    > any object and go into properties & change the color from bylayer to red (for example) and save changes. -everything works fine and when i come out - the drawing B display red colour. -which is ok
    > however if i click on x-ref and go into Edit reference in place.if I now click on
    a layer and change its colour from pink to red. all the objects change colour to red.
    but when i save changes and come out to DWG B the colour of layer donot chage ,, stays pink
    (Visretain =1 , but i don't think its to do with that)
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    It has to do that visretain. It should be zero to reflect any change in properties of object.
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
    AutoCAD 2013
    Nov 2011
    5,986
    Welcome Draftologist to CADTutor.
    Nice Avatar and Name, now that you have fixed it!.
    Per Dipali's suggestion, here is the SYSVDLG information regarding the VISRETAIN variable.
    Map 3D 2014
    Jul 2014
    6
    hey Dipali
    I have tried the same procedure using visretain = 0. and got the same result.
    I think no matter what the value of ViSRETAIN is,, - if you go into EDit _REFERENCE IN PLACE - change the colour of a LAYER ,- Save changes and go out to DWG , LAYER colour do not change.
  5. #5
    Map 3D 2014
    Jul 2014
    6
    Thanks Dadgad.
    for my case/procedure I am not closing and reopening the drawing.
    Changes doesn't show up while working and saving the drawing.
  6. #6
    AutoCAD 2013
    Nov 2011
    5,986
    After closing the block editor, you might try doing a REGENALL.
    Have you tried reopening one of those upon which you had been working, without displaying the changes,
    to see if those changes might display after reopening the drawing?
  7. #7
    Map 3D 2014
    Jul 2014
    6
    After closing the block editor , I have REGENALL -& saved file. closed it.
    & after reopening - No Changes are displayed.
  8. #8
    AutoCAD 2013
    Nov 2011
    5,986
    That about sums up all of my ideas, can't win them all, maybe somebody else will be able to help you, hope so.
  9. #9
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    ok, i tried what you were trying to do. when i chnage the layer color, irrespective of visretain value, the color changes on screen and stays that way in my working seccion. but if i open and see the xref it does not chnage in original file. so i visretain value is 0 and i reload the drawing it goes back to original color and if thevalue is 1 it satys the new color.
    i have no idea about the result.
    Frank Lloyd Wright
  10. #10
    AutoCAD 2013
    Nov 2011
    5,986
    Draftologist, you should spend a few minutes delving into the system variables which are XREF related,
    as shown in the snip from my SYSVDLG window, there aren't really that many,
    and some of them are clearly not complicit. I am not sure if you will have the Express Tool SYSVDLG available in your vertical or not, but that is a very good place to research likely issues caused by variable conflicts.
    I suggest you look at XEDIT, XLOADCTL and XREFTYPE, and pay attention to how they are related as, described there.
  1. Edit text in place
    By koletutor in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2012, 11:23 am
  2. Lisp to change colour from Bylayer to actual colour
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jun 2011, 06:23 pm
  3. edit in place x-ref
    By astonrenoir in forum Architecture & ADT
    Last Post: 4th Jul 2010, 03:03 pm
  4. Reference Colour
    By gw4100 in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2007, 04:17 pm
  5. Edit blocks in-place
    By nelsonrocha47 in forum AutoCAD Beginners' Area
    Last Post: 2nd Jun 2006, 10:45 pm
Tags for this Thread
