Robert J Posted July 24, 2014 Share Posted July 24, 2014 It’s been awhile since I have used CAD and I assume I have a setting set incorrectly for what I want. In the attached PDF you can see the same drawing in the lower left-hand corner. I only want the large one in the center to show and not the small one. There is only one drawing in Model space. Thanks Layout View.pdf Quote Link to comment Share on other sites More sharing options...
Tiger Posted July 24, 2014 Share Posted July 24, 2014 You have an extra Viewport for the smaller one, if you don't see a second Viewport, a layer is probably off or frozen. Quote Link to comment Share on other sites More sharing options...
nestly Posted July 24, 2014 Share Posted July 24, 2014 To verify that Tiger is correct, make sure the Layout is "Model" and use CTRL+R to toggle between all the Viewports Quote Link to comment Share on other sites More sharing options...
Robert J Posted July 24, 2014 Author Share Posted July 24, 2014 Thank you! There were two Viewports stacked on each other. I deleted one and all appears good for now. Quote Link to comment Share on other sites More sharing options...
