Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    Electrical
    AutoCAD LT 2018
    Sep 2007
    123
    Question Revit to autodesk MEP and vice versa
    Im relatively new to both software packages but is it possible to import revit into a autodesk model and vice versa.
    If not which is the way forward Revit or autodesk MEP for future BIM projects?
    Thanks
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,182
    The two platforms are not inter-operable.
    AutoCAD does not do BIM. So Revit is the way to go.
    Drafting is a breeze.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,158
    I agree with Rob. "BIM" (aka Building Information Modeling) was was actually deployed as a marketing strategy from Autodesk to promote Revit back in 2002. So, Revit "is" BIM. AutoCAD based products are incapable of the true BIM process so nix AutoCAD and look into Revit.
    -Tannar
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member
    Electrical
    AutoCAD LT 2018
    Sep 2007
    123
    BIM is something I'm not too familiar with tbh but its something i need to understand asap particularly what it can and can't do. Surley Autodesk MEP is BIM compliant depending upon what level of BIM is required. Is that correct?
    One other thing. What is the best way to become familiar with the BIM process and Revit. I've done the basic Revit autodesk course but that only touched the surface so to speak!! Thanks again.
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,182
  6. #6
    Senior Member
    Electrical
    AutoCAD LT 2018
    Sep 2007
    123
    It's a mine field really. Quite daunting for a beginner who is use to 2D AutoCAD.
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,158
    Quote Originally Posted by GIB39 View Post
    This is not correct. AutoCAD MEP is not parametric, nor is it a collaborative-capable platform, thus cannot be true BIM. It is partial compatibility with certain aspects that the BIM process is made up of (IFC objects, individual parametric parts, object based informational embedding, etc), but either a software is 100% compliant with BIM or it's not BIM.
    What AutoCAD MEP is, is a copy-cat of the Revit MEP platform in certain areas of functionality. It provides you with great tools to generate 3D models, which gives you something called "3D Spatial" models but not "BIM". The #1 item that nixes AMEP as BIM is the fact that only one user can access a DWG file at one time. Revit is different, containing a centralized model that anybody can access at the same time, which in turn gives you a true collaborative environment previously unheard of with CAD applications for the AEC industry.
  8. #8
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Yeah, it was, until the Revit guys redefined BIM to mean the same level of integration as Revit.
  9. #9
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,158
    How is that possible when AMEP showed up after Revit and BIM arrived on the scene?
  10. #10
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    The Revit crowd is getting bigger and louder.
    There's an abundance of "BIM" classes in the Autodesk University archives for AutoCAD vertical products, so clearly someone is redefining "BIM"
  1. convert .ipt to .prt and vice versa
    By AfricanDan in forum Autodesk Inventor
    Last Post: 3rd May 2012, 10:33 pm
  2. Converting MS to PS and vice versa
    By Lithium in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2009, 08:39 pm
  3. ecad to mcad and vice versa
    By larsulph in forum Electrical
    Last Post: 24th Nov 2008, 07:18 pm
  4. Convert .cdr to .dwg or vice versa?
    By todorb2000 in forum AutoCAD Beginners' Area
    Last Post: 29th Sep 2008, 11:12 pm
Tags for this Thread
