Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: acad 2004
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default acad 2004
    Wow,
    I am having some serious issues with this program. First, are there any symbols or anything representing elevations like newer versions or do you have to draw everything. Also, this is something i have experienced with newer versions as well. If you set up a layout and apply a plotter to that layout and apply that layout as the default for the plotter a lot of problems occur. I sometimes have a drawing at say "18x24". Sometimes I just want to print it on out regular 11x17 to save some paper and/or have a smaller size. I am not concerned about the scale changing. I want to go to page setup, and change it from 18x24 to 11x17. In doing so the blue circle just keeps on spinning around having serious issues. Same result if the plotter is not plugged in. Errr!!! So so so annoying.
    Please Help,
    Bjenks
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I used 2005 before updating to 2011, and I don't recall a significant difference in the number of symbols between 2005 and current. No dynamic blocks, but otherwise I think the symbols library in Design Center and Tool Palettes was similar. I'm also not sure I understand the plotting problem, but perhaps 2004 is having trouble with a plotter that's probably much newer?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,182
    Oh, the woes of old software. Is this on a newer OS?
    Drafting is a breeze.
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    If plotter is hooked to network it works fine. It cant always be hooked up to network for various administrative issues. Other devices need to use that cable when not in use. If I just hit page setup manager to change how I print the same thing happens. Nothing works right when plotter is not hooked up. My template is configured for the plotter. I think that is the problem. It is just retarded that I cant change which printer or page setup without it lagging out. As far as tools. I cant find anything except for the basic drawing and modifying and and annotation is limited to dims and text. I dont even see mleaders anywhere. Just quick leader.
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,182
    Focus, tackle one problem at a time.
  6. #6
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    I should bring my laptop.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,818
    When you look at how old 2004 and I take it it is a budget thing, maybe consider purchasing one of the Autocad clones these will at least approach say 2013 version.
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,182
    There are some veteran users and old threads here that can help you out. If you pick one issue at a time, we can get you up to speed to the old days.
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    I recently removed 2004 from my home CAD computer but I could reload it to help answer questions if you'd like.
    I'm retired now.....not dead. I have a few working brain cells left.
  10. #10
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Well I am getting better at it. Right now my main issue is this. If I have snap and polar tracking on I am still running into an issue that I cant figure out. On my pc I can hit line and snap to something. Before clicking to generate a line I sometimes like to drag straight up or down and you can see a trail showing that you are in line with the point below and then hit mouse to generate the line knowing you are in line with the point below. I have gone through tools>options and went through everything. Is this option not available. I thought it was polar tracking. Alls that is doing is allowing me to hit certain angles after initializing the line. I want it initialized before I hit the line if this makes any sense to anyone.
  1. acad 2004 help
    By xolent in forum AutoCAD Beginners' Area
    Last Post: 18th Mar 2010, 11:02 pm
